Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Test Drive Suspension
  1. #21
    Jun 2008
    Ringwood, Victoria
    Bassik, I have said this along with kaanage to you before. What you are after is not acheivable, especially on the assumed budget you have (less than $25,000).
    You are after the handling and body-roll characteristics of your old Honda Integra Type R. It's not going to happen. As I have pointed out to you before, you are talking about a car that was built in the Honda factory, shipped elswhere, completely pulled apart again and re-built with ompletely different suspension geometry, components and even setup which included the re-location and addition of different mounting points. It also had chassis strengthening rails welded into the monocoque. The entire car went from spot welded together to 75% (from memory) seam welding.
    You literally are talking about a race car that was tarted up for the street.
    A front anti-roll bar upgrade WILL help with body roll. As will stiffer, progressive rate springs with matched dampers. To get the handling you are after though? Never going to happen due to the suspension setups you are comparing. Double wishbones and multi links vs torsion beam and MacPherson Struts. Yes, you can make a very good handling car, but if you want the Type R handling experience, sell your polo and buy another Type R. Or buy a 2nd hand Boxter / Cayman which is even better. Probably still has more body roll though.
  2. #22
    Apr 2012
    I always enjoy reading your posts gavs its like my dad is telling me straight.
    I understand all that but I'm not asking for a direct comparison or "please convert my 6R to a Type R" all I want is a little bit less body roll, I'm quite happy with the handling as is and know I can come slightly closer to my Type R driving experience. I read that tonnes of people on here get their suspension upgraded straight off the bat so I wonder hows theirs drives?
    The only reason I went down the ARB path was because it can be easily taken off or changed. Suspension/coilovers can sometimes deter a potential sale.
    As no one has really done the front and back combo i'm struggling to find it hard to do any other minor adjusts to prevent body roll. I also took my car to Kings Suspension and had a guy review my car and gave me advice he said also that a front ARB plus camber conversion would decrease body roll but the 2 go hand in hand. I don't wanna run through tires 50% more then usual. It just seems everyone has different opinion hence why I want to see if someone can offer a test drive.
    Thanks again gavs and I will definitely keep your thoughts in mind however I still want to try and sort this out. If it takes to long I'll end up selling and getting something else?
    Just another question is the Golf Gti better in this department? Body Roll Etc?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  3. #23
    Jun 2008
    Ringwood, Victoria
    The ones I have driven have more body roll but more compliance. Look, do the front, it's a cheaper mod than the coilover route, it just requires a hoist and subframe location pins when you drop the subframe. It sounds scary but it's really not that bad. I plan on getting a front anti rollbar, I'm just waiting for some cooler weather to work on the hoist
  4. #24
    Apr 2012
    Ahh so your planning on doing it yourself as well down the track? Have you thought about springs or coilovers or is that not your forta?
    I'm in no immediate rush but I'm getting anxious. So is there a reason to why you want to the front done as well, and you going APR?
  5. #25
    Jan 2011
    springs are good. i got the 25/40 h&r in mine plus the RSB. springs made a huge difference and the car looks better. still remember the first corner i took after i had them installed was so amazed
  6. #26
    Jun 2008
    Ringwood, Victoria
    Once the stock dampers give up I will look at replacing the suspension but I am looking at the front anti roll bar to dial a bit of underdetermined back in without sacrificing body roll. This should couple with new tyres just nicely.
    Nope, I'll be getting either eibach or KW.
  7. #27
    Apr 2012
    Quote Originally Posted by JexL View Post
    Ahhh hey JexL.... You sent me a PM once. So you rate springs highly? I didn't want to get this done but I'm tempted, you'd basically have the same setup as me if I went your path.
