Yeah I've got this mag I read that too. Was very impressive the guy also mentioned that getting this pair setup would only really help when I hit corners 110km and above, if your cruising at 40-60kms your bound to feel anything at all as they only tuned them to come into affect then their pushed over 30% tension. That's was another thought as well.
Paired with my white line I need to find out what percentage stiffness increase is there's from lowest to hardest tension setting? I called white line and they couldn't give me a straight answer as it wasn't measured by percentage increased stiffness but more diameter on the beam. Having the advantage of adjustment in the back is good though as it provides more flexibility. I think I would be able to pair the 2 quiet easily, save $200 on back as well.
So although its all well and true I'm still not completely satisfied without having at least someone having the same setup or being able to test drive one.
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
