Results 1 to 4 of 4
Thread: TDi front wheel bearings
    Dec 2005
    Rockhampton Qld AU
    Hi. I've had a quick check but can't find any bearings to suit.
    I've come across hubs with the bearing in it so is this what I have to do?
    Can someone supply me the part number and maybe a link to a vid to give me an idea what to do?
    Thank you.
    Neil
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Usually the bearings are sold with the hub in it on those cars.
    I'm sure if you take the bearings out and contact a wheel bearing supplier with the specs you would be able to get them but by that time why not just buy the complete assembly and have the car fixed up in minutes with no bearing press and time needed?
    Dec 2005
    Rockhampton Qld AU
    Thanks mate.
    Have the bearing\hub assembly. Checked a video and am a bit daunted atm.
    Might have to get local mech to do it for me.
    Dec 2005
    Rockhampton Qld AU
    Done one side and vibration gone. Fairly easy. Needed a press.
    Have to do the other side cause still noisy.
