Originally Posted by
SunnyCoast_GTi
Mine came the same. Clay bar will not get rid of swirls, only using a machine with a stage one correction will remove it. A professional detailer will charge you about $170 - $200 for the job.
And then a good detailer will charge $400 to fix that.
Especially since VAG non-metallic whites (like Candy and Glacier) are rock hard.
Resident grumpy old fart
