Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 77
Thread: Suspension talk
  1. #51
    Jun 2008
    Emerald, Vic
    Oh dear, I didn't want to hear that, I HATE knocks and bumps in suspension... Is it indemic of all v1's or just your set? Is KW any use in resolving the issue?
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
  2. #52
    Jun 2008
    Ringwood, Victoria
    Suspension talk
    Did you put new stretch bolts and strut tops in? If not, I'd look at them first.
  3. #53
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by BLN355 View Post
    Fronts, it gives a light annoying thud on rebound on small dips/bumps in the road during normal cruising conditions.
    Check if the nuts holding the damper shafts to the strut top haven't loosened off
    Resident grumpy old fart
  4. #54
    Jun 2008
    Ringwood, Victoria
    Suspension talk
    Quote Originally Posted by kaanage View Post
    This too
  5. #55
    Aug 2011
    Brisbane, Queensland
    Quote Originally Posted by pontiff View Post
    How do the street comforts compare to the V1's that I'm going to install? I want some sort of compliance and absorbsion. Yours sounds ideal for what I'm looking for. With boavista and stock height, it looks like its on stillts, needs a slamming
    Street comforts are a bit pricier than v1's (I paid $1,332 including shipping from Motorsportworld in the UK) and can't be wound down quite as low (still low enough though, 50mm at the back), but given their intended purpose I would expect that they have a better ride than the v1's (though to what extent I don't know). Gave it a little squirt up the twisties to Peachester on the Sunny Coast this afternoon, was wet so didn't push my luck but still had some decent hustle going, and was quite impressed that they could ride so well and deliver that sort of flat, chuckable handling. The ultimate test will be the bumpy tight corners on Mount Mee, so I will report back when I get a chance to get up there (if it ever stops frikkin raining).
  6. #56
    Jun 2008
    Emerald, Vic
    Installed mine last night / this morning and my front left does the same thing ((( I installed all new stretch bolts and such like on both sides. Everything is torqued to the correct values and I installed new strut top mounts and bearings (even tho old ones are only 40k old)
    Any suggestions? It's rather unnerving to drive like that, sounds like something is going to come loose, but it's all tight
    At the moment it only seems to be the FRHS
    Sounds like a spring 'twanging' sound and appears to be when going though a sharp downward motion (pothole etc)
    Are they too low perhaps? They are set to just under half
  7. #57
    Jun 2008
    Emerald, Vic
    What is the purpose of that little spring at the top, I'm wondering if its moving?
  8. #58
    Dec 2012
    Gold Coast
    ive had coilovers make this noise in the past, very annoying, it seems to happen when they take a sharp impact? be it up or down, or if you unload a corner and then the next big bump they hit, the noise comes... only way to fix it i found was to re-tighten the main bolt on top of the strut, however it seemed to be a short term fix and within a couple of days the noise would return... not sure if its the same thing you lot are experiencing?
    I was all set to purchase some kw v1's as well until I heard of this noise from BLN355 a few weeks back, so now contemplating hr monotubes but unsure if anyones had a bad experience with these too...
  9. #59
    Jul 2012
    Coogee, NSW
    its a helper spring, so when the car is jacked up and the coilover comes off load it all doesnt fall apart, i think*
    also watch this, i know a mate of mine had a similar problem and apparently this works
    https://www.youtube.com/watch?v=Lvz85ywK8lw
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
  10. #60
    Dec 2012
    Since the springs are still new, have a look if the coils have any marking on them - see if they are hitting each other
    This is the first thing I would check as it's quite common and can be rectified.
    I've had coilovers that made noises as well and I know the feeling - it's very annoying and could be difficult to diagnose as there are more "moving" parts than your standard suspension.
    The other thing is with all the rain, a bit of moisture can sometimes mask the noise a bit - which is what I"ve also experienced. So, just test it out when it's a clear day as well as when wet, just in case.
