Results 1 to 10 of 10
Thread: What kind of spare wheel does your Comfortline have?
    Sep 2009
    WA
    Blog Entries
    1
    Question What kind of spare wheel does your Comfortline have?
    There seems to be some conflicting data about what spare wheel the Polo has.
    Reports state this;
    All variants come with a full size steel spare wheel aside from the Comfortline Sport, where the same spare is limited to 80km/h due to the Sport’s larger alloys.
    2014 VW Polo review | first drive: Car Reviews | CarsGuide
    And the VW Specs also say "Spare wheel, full size steel"
    http://www.volkswagen.com.au/content...my15-5-web.pdf
    But when I look in my boot I see an 80km/h restricted wheel. I have a standard Comfortline 2015.
    Pic is from the web but I have the same yellow stickers on mine.
    VW Tiguan 2018 162TSI Highline
    VW Polo 2015 81TSI Comfortline
    Pacific Paradise QLD
    My 2010 has one of them as well Took it out and pumped it up yesterday
    not sure why the one pictured has the speed restriction on it when it has a full size tyre from what I can see.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2010
    Melbourne, VIC
    Maybe the web pic is where someone has fitted a normal tyre to a space saver rim
    Resident grumpy old fart
    Dec 2008
    Perth
    My 2014 Polo Comfortline has the 80km/h sticker on it, but the tyre is exactly the same as the ones on the alloy rims, Conti Premium Contact 2 185/60 R15. So this had me a bit confused also, but I obviously stuck to 80 for the few days when I had a screw in a tyre.
    BTW, the automatic pressure detection thingy works great, there was a screw in the tyre but you would never know otherwise. Only after receiving the warning did I closely inspect the tyre to find it.
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
    Quote Originally Posted by kaanage View Post
    my thoughts too.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    The standard-fit tyres on the pre-facelift (before 2015) Polo comfortlines are 195/55/R15
    All comfortlines have 185/60/R15 spare tyres and they will all have the 80km/h speed restriction label on them to account for larger alloys (from the Sport Pack, for example). If the spare is on the rear axle, you can probably safely drive at whichever speed you like. It's when the spare is on the driven axle (front) that there can be an issue due to the different wheel rotation speeds due to the slightly different tyre diameters, and in this case the safest option is to adhere to the 80km/h restriction so you don't destroy a differential.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Oct 2010
    Melbourne, VIC
    Using a space saver on the front is insane. With space savers, you should always swap one of the rears to the front if you puncture the front.
    Sent from my 2014817 using Tapatalk
    Mine has 195/55/15 on mags and a 185/60/15 on a much narrower steel rim for the spare Hence the speed restriction I would think
    The spare is actually 8mm more in diameter than the regular tyres.
    With the extra luggage layer in the boot it would be hard to get a full width mag in there
    Aug 2013
    I've got the exact same tyre as pictured on my Comfortline with sport pack.
    I found a spare boavista rim on ebay for $50 and I managed to fit it in my boot for spare wheel purposes, can't fit the toolkit in though.
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
