Results 1 to 3 of 3
Thread: Stud Conversion Kit - I need Bolt Diamater for wheels
    Jan 2015
    westlake, qld
    Hi All,
    Just quickly wondering what the bolt width is for a 2010 Polo GTi, Some people selling conversion kits have 14mm or 12mm bolts.
    Thanks for any help guys. By the way, if it helps, this is the kit I intend to buy
    VW Stud Conversion KIT 14mm X 1 5 TO 12mm X 1 5 20pcs | eBay
    M14x1.5
    Oct 2010
    Melbourne, VIC
    Yep.
    That kit you linked will work if you want to use the smaller threaded nuts (possibly more choices than 14x1.5). The stud will be slightly weaker but should not make any difference unless you are offroad, endurance racing.
    Resident grumpy old fart
