It seems obvious something is rubbing on the belt as the markings are rubbed off all the way around. What is that bit of rubber at the top of the picture that goes right to the outer edge of the pulley? Is that still attached to the belt or a broken off piece caught up on the pulley?
I just had a feel around my car (hard to do!) to find what it could be. Has a bolt come loose somewhere and is now rubbing on the belt? A hose clamp? Only other thing I can think of is that a schmuck left one of their tools under your bonnet at the service and it has dropped in some cavity and been rubbing. I wonder if you have a screwdriver or spanner resting in your under tray.
The only thing more puzzling than your problem is that a dealer needs to order in a normal everyday stock service item.
