Results 1 to 7 of 7
Thread: Stop-Start Polo 6C
    Sep 2009
    Stop-Start Polo 6C
    Hey guys,
    Noticed one slight difference between my Golf R and the Polo's stop start system... the R can be set to start hen touching the accelerator pedal, or foot removed from brake (if in acc mode). The Polo however seems to auto start whenever the foot is taken off the brake. Is there any way to change this to an accelerator tap??
    And before you ask... it is particularly useful in heavy traffic, normal driving isnt an issue but sitting there with your foot on the brake when stuck stationary for close to an hour gets tiresome.
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by maraach View Post
    Hey guys,
    Hey mate, this would be due to the autohold feature which your golf R will have, but your Polo won't. When you have autohold enabled it wont start untill you press the accelerator as the auto hold 'holds the brake' for you, so when you press the accelerator the car knows you want to move foward, but without autohold it relies on brake pedal input, e.g; when you take your foot off the brake it knows you want to move foward, so it starts again.
    Dec 2012
    brisbane
    polo has auto hold for 2 seconds. sorry don't know if you can switch the start to accelerator
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by xtfalcon View Post
    Im talking about the button auto hold feature available with the electronic handbrake, totally different system mate and is exactly the answer to OP's question.
    Dec 2012
    brisbane
    ok sorry don't know about what is in the golf
    Sep 2009
    Quote Originally Posted by The One View Post
    Thanks for clearing that up The One. I thought it might be the case but wasnt sure. Does make a lot of sense though.
    Sep 2008
    Slightly obtuse topic...
    From what I read, the auto hold is a lot smarter than that. Might max out at 2 seconds with a timeout, but also sensitive to gradient, throttle position or rpm, clutch position.
    Presumably it will be adjustable in VCDS. Yeti IIRC has three settings something like OFF/soft/strong. Diesel manual is better on the middle setting.
    SSP374 Traction Control describes the operation of the Hill Start Assist system in detail.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
