Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Startup RPM
    Aug 2012
    Startup RPM
    Hey Guys,
    Just an observation, but I was wondering if anyone has experienced the same thing or knows what this could be...
    So when I start the car first thing in the morning, the RPM sits at about 1200 during it's startup phase to warm up the engine (I think that's why it does it - correct me if I'm wrong). I always wait until it goes down to about 800RPM before I put it in gear, don't know why, I've just heard it's good to do that.
    Lately, however, when I start the car first thing in the morning, it just goes straight to 800 which is what it's normal idle RPM is... The weather has been even colder lately, too.
    Does anyone know why this would be the case?
    Thanks in advance!
    MY16 Golf GTI Performance Pack
    Previously: MY12 Polo 77TSI
    In The Family: MY15 Golf 103TSI Highline & MY15 Audi RS3
    Jul 2011
    When the temperature is too cold (under 10 degrees from what i can tell) the engine doesn't do a warm up of the O2 sensors (which is where it revs at 1200rpm).
    I think it's designed like this so not to do any damage to the engine as cold temperatures mean the oil is much thicker and harder to pump into the pin holes in the cylinder heads. Cold starts are always bad for an engine and if you are revving a stone cold engine at 1200rpm for 2 mins with no oil it's all bad news.
    Also the cylinder block itself would have seriously constricted from the cold weather and if the block is not gradually warmed up with the pistons they could seize.
    If you look at the revs they go from 800rpm down to 600rpm after about 2 mins, but you can tell by the fuel consumption that it is running slightly rich - like a choke
    In a nutshell do not be concerned - its quite normal
    Aug 2012
    Ohhh! That makes perfect sense! Because when I put the car in the garage overnight (which is obviously warmer) it does go to 1200RPM when it starts. But when I leave it outside (where it probably gets below 10 degrees) it doesn't.
    Thanks heaps, Nomad! Very informative and interesting! Much appreciated!
    Apr 2013
    I have a question in regards to cold starts, when i apply my brakes on a cold start its like it switches the cold start off and the revs then drop to 800rpm, once i let go of the brakes it goes back up to 1200rpm, no idea why... anyone else facing this?
    Aug 2012
    Quote Originally Posted by EDM12T View Post
    That's really odd... I usually hold my foot on the break while it's at 1200RPM and it never makes a difference. :\
    Apr 2012
    Bridgeman Downs ,Brisbane
    yeh ive had this happen to me aswell
    Jul 2011
    It has something to do with the brake circuit controlling the turbo.
    The revs don't actually change (well only a slight bit) but the exhaust / engine note changes quite dramatically. I think what happens is when you hit the brake it automatically opens the waste gate on the turbo and it vents the boost which changes the sound of the engine/exhaust.
    Again pretty normal
    Apr 2012
    Quote Originally Posted by nomadx38 View Post
    Again pretty normal
    but there wouldn't be any boost on start up and idle would there?
    i know its normal though
    Jul 2011
    Technically there is always boost becuase the turbine in the turbo is always spinning from the exhaust gasses. The difference in sound been whether its got the wastegate open or closed.
    Startup RPM
    Just to add my experiences to this thread:
    TDI Polo's don't ever seem to do a high rpm idle to warm up – it's got down to 2 degrees and still it just goes straight to 800 rpm.
    Our (petrol) Megane does the same things as your Polo's do – a slightly higher idle (about 1,200 rpm) on cold starts, but below 10 degrees it goes to 800 rpm for a few minutes, before selling down to its usual 500 rpm idle.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
