Results 1 to 5 of 5
Thread: Standard wheel nuts on aftermarket rims
    Aug 2013
    Hi guys quick question.
    I've purchased a set of enkei rpf1's for my gti and I'm picking them up tonight. Now my question is will the standard wheel bolts fit in my new rims..? I have never taken one off my polo to see if they are big and bulky. What have other people with aftermarket rims done?
    Thanks
    you mean bolts?
    unless the enkei have a ball seat I wouldnt run them, running the wrong seat type reduces the contact area between the bolt and the wheel. can cause damage to either the bolt or the wheel, or cause vibration
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2013
    Orange NSW
    If they are original, they are bolts. You can buy nuts and studs from trackstuds.com if you want to convert. The Enkei are more than likely going to be taper not ball seats.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    May 2012
    My ultraleggras came with nuts, but I still used the oem lock nuts. As mentioned you need to check the seat type but also the length as some after market wheels can have a thinner or thicker centre due to offset or material and may need shorter/longer nuts or the can go to far through and foul on the hub or not have enough grip in the thread and break.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Aug 2013
    I pulled one bolt out and check and they seem to a good fit and still have heaps of thread on the bolt so should be fine.. Otherwise I was up for $200 to get some new ones even though I would prefer if they were black
