Originally Posted by
brad
Indeed.
The only way i can get 18" rims with 35 series tyres to be anywhere near a corrective height is to go 305 or 315 width. In fact, it appears a 225/45x18 could well be the ideal width/aspect combo on an 18" rim on a Polo.
I had the same issue (speedo reeding 8% wrong) on the Octavia with 205/55x16 as OEM. 225/45x17 (with 17" rims of course) helped a bit but 225/55x16 have got it as accurate as I want (it still reads ~3% under).
None of the other cars I've owned in the last 10 years have been half as innacurate as the Skoda - includes Mk3.5 Cabrio, Avensis, Outback, Outlander, Calais, Falcons, Bluebirds, Mondeo, Liberty and a few others. The VWs are within the ADRs but only just.
The other thing to note with the innacurate speedos is that the odometer is also innacurate - but not as bad as the speedo. On the Octavia, if you checked the odo against a check length on the hwy 5km was actually 5.3km on the odo. This means that when you get the 15,000km service you have only done ~14100km.
The problem one has is not only finding the right size but that it is legal.
In QLD you can only go up in diameter by 15mm over the largest tyre fitted to the model of car or under by 26mm.
You must also put on a tyre with at least equal or better load index as well and some odd size tyres are a bit sus in this.
You must after changing still have your speedo with ADR specifications.
Changing to larger diameter rims does NOT allow you to exceed these measurements
