All speedos are designed to read over by up to 10%
Has its advantages
Hi all
I'm sure this has been discussed but I couldn't find it in a forum search so here goes... Sorry if this is a duplication.
Does anyone have any solid idea on how accurate the speedo in the Polo is? Travelling back from Adelaide to Sydney I was using my GPS a fair bit and there was a fair discrepancy between what was on my speedo and what my GPS was tracking me at. In a good way though, as the speedo readout was a fair bit lower than the GPS.
Generally, the Polo's speedo seemed roughly about 8-10% slower than the GPS said. For instance, I did a lot of cruising at 100-110km/h. Where the Polo's speedo said I was doing 118km/h, the GPS was tracking me at dead on 110km/h.
Similarly, at lower speeds, when I was doing 65km/h on the speedo, GPS said it was more like 60km/h
Anyone got any thoughts on this? I don't know which is more accurate, the speedo or the GPS?
Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
Instagram: @lemonskin
Has its advantages
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
Generally most cars speedos are set from factory 6-8% faster than 100kmh or the legal limit... and these cars are no different.
Speedo reads 117, GPS reads 110 on the dot, so about the same as you mate.
Mk8 Golf GTI
If you have the time you could read the guff on ADR 18/03 Vehicle Standard (Australian Design Rule 18/03 - Instrumentation) 2006.
Section 5 - Specifications. Subsection 5.2 ....
I'm sure that will make it all clear as crystal.
( Ex-Shire myself).
2012 MK6 GTD CW DSG Seattle's 3M Black Tint, Michelin PS3's.
Basically the rule is that speedos can be up to 10% fast plus or minus 4kph
They cannot legally read under
Our Polo is 7 k over at 100kph Checked with GPS and VCDS plugged in . Couldnt correct it due to limited control
The Passat is 6 k over at 100k checked with GPS and with the Canbus reading Havent tried to correct it yet
Cant fix either with tyres as would need to be to big to be legal 40mm for the Polo and 25mm legal oversize
What i personally find disconcerting now is that there's a couple of speed cameras where the Hume freeway north of Melbourne goes from 100 to 110 kph limit, I have my GPS reading 109, car speedo reading 117 & the camera still fires as i drive through!
Apprehensively checking the mailbox each arvo... I think there was an issue with these cameras a year or so back, & they turned them off for a while, but they're back on now & have a photo of me...
GPS 100 v Speedo 103 for me (aftermarket wheels)
MY18 Golf 7.5R - Ecotune Stage 1
Mazda RX2 - 13B Bridgeport GTX4202R
