Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: sound actuator Polo GTI
  1. #51
    Re: sound actuator Polo GTI
    You are correct. If your car is functioning as intended but you don't like the noise the actuator makes, go ahead and disconnect it.
    Gavs was referring to a fault a few GTI's seem to have where the actuator causes a rattling noise in the cabin as well. If you were experiencing this, obviously it would be worthwhile getting it fixed under warranty and not just sweeping the problem under the rug.
    Sent from my HTC One XL using Tapatalk 2
    MY12 Polo GTI
    Factory Options:
    Candy White | 3dr | Comfort Pack | Bi-Xenons | Alarm | Jacky Cloth
    Customisations:
    RNS510 + SSD | Bluetooth | Watch this space!
  2. #52
    Sep 2012
    NSW
    It really depends on the 'drone' you are experiencing. My GTi was making rattle noises under hard acceleration and a drone when holding at a certain rev for long period.
    I took the car into VW and they found that there were cables moving around against the firewall which they fastened, and also that there was no padding around the speaker.
    After this service, I have no complaints and enjoy the noise the sound actuator creates.
  3. #53
    Oct 2012
    Thanks for your help Gents
    I'll disconnect the actuator and then delete the mid muffler to see if that improves the cabin sound
  4. #54
    Jun 2008
    Ringwood, Victoria
    Will make it worse......
  5. #55
    Mar 2011
    Quote Originally Posted by Polo_GTI View Post
    What makes you think deleting the muffler will improve cabin sound?
  6. #56
    Oct 2012
    I thought most of you blokes deleted the mid muffler for a louder exhaust note?
    What am I missing here?
  7. #57
    Jul 2012
    Depends what you mean by "improved cabin sound"
    I wouldn't say removing the middle muffler made the exhaust a lot louder, but it gives it more bass.
    Mk8 Golf GTI
  8. #58
    Oct 2012
    then in turn, more bass would improve the cabin sound then yes?
  9. #59
    Jun 2008
    Ringwood, Victoria
    No. The problem is that the resi delete doesn't really yield that much noise unless you really have the taps opened up. It's not so much an increase in bass note, but without the sound actuator going it doesn't sound as good, it's quite tinny.
    I only took mine out as a temporary measure to get the dsg ignition cut noise, for a good exhaust note you need to go aftermarket.
  10. #60
    Oct 2012
    Quote Originally Posted by gavs View Post
    Cool thanks Gavs. I actually don't mind the noise from the actuator, it just has a drone sound to it when gearing down and holding revs. Otherwise it's ok. At least it's not rattling.
    I will go for the resi delete soon so it's a little louder on the outside. Ill see how it sounds with both actuator in and out
