Maybe have a look at Koni FSD dampers. The seem to have a very large difference between the low and high speed compression damping which should make the car less jarring without compromising performance.
I have seen a few posts where people have found them to be great for road use and not quite so brilliant on the track (which isn't a concern for the vast majority of people).
Resident grumpy old fart
