Volkswagen maintenance requirements as per the service schedule, based on time intervals;
- Engine oil and oil filter every year.
- Pollen filter and brake fluid every two years.
- Spark plugs and fuel filter (only if equipped and excluding internal tank filters) every four years.
At a minimum, it is recommended that the engine oil and oil filter be replaced, as well as the brake fluid if age exceeds two years since last fill.
If the vehicle warranty has expired, the pollen filter and spark plugs can be replaced based on condition if you prefer. I do not know the reasoning behind a time interval for spark plugs.
The air filter is replaced every 45 000 km and has no time interval. Avoid opening the air filter housing or remove the air filter unnecessarily. The filter seal is not designed for repeated fittings and should not be disturbed.
