bump.
62 views no one got any help to give about fitting grills?
bump.
After some solid googling for you, apparently you remove the foglight trims (this is in the manual under lights I think) then there are a few screws.
Here is where I read it
UK-POLOS.NET • View topic - POLO 6R FRONT GRILL
Sent from my GT-I9197 using Tapatalk
Hiya. . . I fitted this exact grille on mine
You remove the two fog covers using a flat screwdriver with some thick black tape over it (so you don't damage the paintwork), and at the very bottom left (and right) of the centre grille. . .there will be a tiny gap which connects to a small 1cm-high bit of the fog grille (it's actually right below where the blue protective film ends on the left side of that grille). . stick it in there and look to pop out the fog cover.
Then pull out the centre grille , if you have trouble getting it out - then look at your new grille to see where the clips are and stick your screw driver in between it, and the paint, as to where the clips are.
It's really easy buddy. I hope I explained that half decently.
Thanks for the help,
I found out from another post that there is a tool included by VW in the toolkit for removing the fogs!
This is the 'Extractor Hook Tool' found in the VW toolkit and the purpose of these are to pull out the fog surrounds without sticking anything into the gaps and paint, the little tab goes into the hole and pulls out the fog surround with a bit of pressure
Grill was fitted today with minimal problems
MY13 66tdi polo 'ocean blue', DSG. Comfort Pack, Sports Pack. RNS510 installed. Parking Sensors installed
