Results 1 to 10 of 10
Thread: Running cables through firewall
    So I'm trying to run cables through my firewall at the moment. It has stumped me.
    I've found the grommet hole everyone talks about under the windscreen wiper passenger side but can't get to it on the inside. I've even taken off the glove box.
    Any one got any tips or help?
    Dec 2008
    Sydney/Canberra
    On the top side of the passenger's side chassis rail where it meets the firewall.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Any photos? Can't see it anywhere? Do I need to remove anything to get to it
    Feb 2014
    South Africa
    There is also a hole behind the glove box lower down. I can't really describe it but that's what I used to route my audio cables
    All good, got it through
    Now to find the best place to get acc power
    Pacific Paradise QLD
    Get it from the fuse box under the steering column Plenty of spares in there or buy a piggy back fuse from Jaycar and stick it in one of them in place of the one that's there Don't use airbag or similar fuses though
    Feb 2014
    South Africa
    What exactly are you wiring up?
    Do u know which fuse the cig lighter is? So stupid these cars don't come with a fuse map
    Quote Originally Posted by LD_mart View Post
    If you Google "Polo fuse map" you would have got this The green one is a Polo but the original site had a map as well
    Took 125milliseconds to find this https://www.google.com/search?q=volk...w=1536&bih=745
    Google is ALWAYS your friend
    Aright Ill do the work for you Look at the bottom row of fuses. At the right end are mini fuses The rest are full size
    Look at the third from the right end bottom row full size fuse. It is number 27 in tiny numbers underneath it Get a 10 amp piggy back from Jaycar and stick it in there Hook whatever you haven't told us that you are fitting onto the bullet connector on the end of the wire that comes off the back of the fuse.
    No you can t solder a wire on to an existing one Ive tried and am used to soldering electronic parts.
    As long as you aren't hooking something that requires more amps it will be OK
    It would be nice to know the full facts when you want help. Like what you are installing etc.
    No need to be so angry about helping me. I asked u a simple question, if u didnt wanna help you shouldnt of.
    Well its all done now, i put in fog lights. Thanks for the help!
