Cheers for the link. i figure while im doing the other mods ill run the cable at the same time. at least ill know the recieption will be as good as it possible can be without fitting a satilite to the roof
The cable to the rear? There's a VW number, but this is much much cheaper @ ~$15 total.
eBay Australia: Buy new & used fashion, electronics & home d
I bought one a while ago but it's waiting for when I do an audio install. 5 Meters should be enough but you can ask for an extra 50cm for free
To be honest, I've haven't had issues with my current one under the vent (which is supplied with units you get from eBay), though I imagine that the signal would be much better undercover and around tall buildings with the sharkfin.
Hi me again. I cant get my pics up!?!?! Grrr. Who / how do I talk to to resolve??
John
Are you uploading to somewhere like photobucket and then using the image ( [IMG] ) code at the beginning and end of the link?
Hooray - this is where I ended up putting my GPS antenna, and someone agrees it's a good place!
The driver's side A pillar has no other wires on it in my GTI, and I ran the mic and 3G antenna down the passenger side A pillar, so there was plenty of space. I ended up using electrical tape all the way down the corner of the pillar to hold the wire clear of those scary clips too.
EDIT: I'll put a photo in if I take that pillar off again, but for now I want to let my poor fingers recover. It's NOT a fun piece of trim to remove!
Couple of questions for those who have done this install.
1) What is required from a VCDS perspective to get the Satnav directions to appear on the MFD+ of a GTI?
2) Is there any requirement to actually run the antenna into the door? I've read that the fin antenna on at least the GTI has an extra green cable/connector that drops down behind the factory installed RCD510 to provide GPS connectivity?
Thanks!
MY12.5 Candy White 5 door Polo GTI. Upgrades/Mods = RNS510 H LED, RVC camera, Auto Lights Dash Sound Actuator GTI button, Gavs Footrest(!)
WIP = Miltek Turboback Exhaust, Cold Air Intake, Red Stuff brake pads (Nov '13)
