Im going to put the RNS510 in my MY12.5 polo Which already has the bluetooth. Will the mic from this work with the RNS or will i have to get anouther mic
Thanks. Great info ! Gonna put the unit in later for my cousin![]()
Works fine, but the voice recognition is still terrible![]()
Depends on your accent to be honest. I've had a poor time using it (most voice systems hate me, even siri) but maybe it'll work with you.
I tested the on at the dealer. i told it to call kim but it kept calling daniel they only way i could get it to work properly was say the full name. All the names on my phone are first and last names and if i didnt give the full name 9 times out of 10 it picked the wrong name. i wouldnt say i had accent but it might have been model for europe voices i guess
The factory position for the gps antenna is actually the sharkfin antenna on the roof.
The blue one is the GPS (white is phone, plum is AM/FM) but sadly there is no cable running from the back of the Polo to the front (and you'd need to take off a bunch of panels to run one) . The best spot to put it is on the top of the AC vents, it seems to get a good amount of satellites there.
I used to work for the OEM manufacturer of sat nav systems for Toyota vehicles.
As long as there is a "clear view" to the sky from your location (ie. No metal above the antenna) then you will be able to get enough signal.
As readerrOr points out, the official location is the best but there is a lot of work to retrofit.
Stick to the vents
2010 Polo GTI - 5dr Flash Red
Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
Planned upgrades: Amp, 3 way speaker install
Planned mods: APR tune, Brembo brake upgrade
I see, makes sense. Anyone got the part number for the cable? going to put in a RVC so might as well do it at the same time while i have some of the panels off going to the screen.
