So, the 2nd part of the install was the Bluetooth.
I purchased the kit from the Spanish seller on Ebay, Bluewagen. Kit
The first thing I did was look at where to situate the actual bluetooth unit.
I wasted a fair bit of time looking at installing the unit behind the air con controls.
What I worked out was:
1. If you have manual air con controls then you can only install the unit under the seat (I chose passenger)
2. If you have the semi auto controls then you can install behind the climate control unit
Anyway, I chose to put the unit under the passenger's seat.
I have a GTI, so it comes with the seat drawers, so I needed to pull the unit out of the protective polystyrene case. I bought some velcro tape from a $2 shop and attached 3 strips to make sure the unit doesn't slide around.
To route the wiring, you'll need to pull the panel on the centre console off.
This comes off with a little bit of pressure.
You can see that it is held in place with a kind of pressure fit velcro.
And another view
Once you have the panel removed, pull most of the cable which connects to the Bluetooth unit through that gap and then you'll need to remove the passenger side kick panel.
To do this, remove the little area reserved for the emergency pncho and then pull with reasonable force on the panel. It is attached with two plugs and will pop out easily.
Then finally, you'll need to pull up the scuff panel to give you the most amount of room to play with.
Once you do this, you'll need to get your hand in under the carpet and pull the cable through, under the passenger seat. You'll notice by felling around that there is a join in the carpet between the front and the back area directly under the passenger seat. Pull the cable through to here and then ensure that the cable going back to the head unit goes directly to the centre transmission tunnel and back to the head unit.
No pics here but it's simple to do.
The remaining thing to do is plug the cable into the Bluetooth control unit, stick down with velcro and then reinstall the scuff plate, passenger kick panel and centre transmission tunnel panel.
