Thanks BKR. Much appreciated.Without the programming:
1. There is nothing on the MFD about the BT module or phone. Except when you stream audio, then the page that normally has the radio audio source/radio station has "bluetooth".
2. To pair the phone, turn the car on (I think the BT module is only discoverable for a little while), pair to "VW PHONE", and use code '0000'. The phone button on the steering wheel will answer, hangup and redial, but you have to make new calls from the phone itself.
3. Nothing comes up on the MFD or the radio about incoming calls, except the word "PHONE" appears on the radio.
4. BT streaming works well with an iPhone 4. I have seen other people complain about the quality, but it seems OK to me. One tip: you need to have something actually playing on you device before the BT AUDIO option comes up under the media menu on the radio.
Once it was programmed, it does all of that, plus the MFD page appears with the phone book, recent calls list, and the callers name is displayed for incoming calls.
