Results 11 to 20 of 27
Thread: RNS510 and 9W7 Bluetooth in new Polo 6R
    Apr 2011
    Elsternwick, VIC
    The standard steering controls work without coding. The telephone and voice control buttons don't.
    Just wanted to clarify, you cannot answer calls from the steering wheel? Where do you answer them then? Can this be done on the RNS510 or must it be done on the phone?
    P.S. Anyone have any luck paying for an install on an RNS510 and/or 9W7?
    Jun 2008
    Ringwood, Victoria
    That is correct, the module needs to be activated for the buttons to work via VAGCOM.
    Apr 2011
    Elsternwick, VIC
    What is the most cost-effective way to have that done? Will a dealer do it for you?
    Jun 2008
    Ringwood, Victoria
    Unless you are mates, they might bit*h about it if it's not the unit they would fit or the factory installed unit. Otherwise, find someone on here that has one to give it a try for you or see if you can borrow theirs You will need to make sure it is the latest version of teh Ross-Tech software though...
    May 2011
    Yeerongpilly, Brisbane, QLD
    Hey guys, does anyone know if it's possible to access your phone contacts via Bluetooth on the Polo standard fit stereo? I'm struggling to find out if it's possible. Answering calls isn't a problem, works fine. Just wondering if the contacts is possible?
    Quote Originally Posted by YellowLemon View Post
    Most likely the Spanish harness will work fine as-is, however it has the microphone connection bridged between the RNS510 and 9W7 Bluetooth. The RNS510 has a separate microphone pass-thru, so I changed the pins as detailed here:
    The Volkswagen Club of South Africa - View topic - Golf VI GTI RNS 510 and 9WZ Bluetooth Install - Long Post
    and
    Volkswagen RNS 510 Microphone Connection for voice control | my-gti.com (Option B)
    I also cut the microphone wire to make installing easier, and then rejoined it at the centre console to the piggyback harness (see point 4 below)
    3) Removing the old RCD310 system
    Follow the excellent instructions by GraveDilute, this guy is awesome.
    http://www.vwwatercooled.org.au/f128...tml#post635681
    Particularly note the noob hint to remove any CD's first!
    More pictures here: (note this is for a Golf though! it's different but gives you some idea)
    HOW TO: Install a Bluetooth Hands Free with Mic.
    4) Wiring the microphone
    After removing the RCD310 I wired the microphone, starting at the cabin light at the top. This all clips out very easily with minimal force. Note there is a piece of black plastic where the microphone belongs which has to be gently clipped out with a long screwdriver.
    You don't have to unscrew the sunvisor, mirror light or roof handle at all.
    Just unclip the driver side A-pillar trim buy pulling firmly starting at the top. There is no Torx screw under the Airbag logo, it's all just clips. I did this with no damage. In fact, there is not even an Airbag under the A-pillar trim I could see.
    Here is a guide for the Golf, again note it is much easier in Polo because there is no Torx screw:
    Volkswagen Golf upper A-pillar trim
    Use a long rigid wire (like solid copper electrical wire) to push the microphone cable from the dome light to where you unclipped the A-pillar trim. No need to remove the headliner at all as there is plenty of space at the front near where the headliner meets the windshield.
    Route the wire down the A-pillar, and unclip the trim at the driver's side of the dash, and again use the rigid solid copper electrical wire to push the microphone wire to the centre console where the radio was.
    5) Install RNS510 radio
    Again just follow GraveDilute's photo instructions above. I put the GPS above the air vents too, perfect spot for it. Removing the air vents required some jiggling, but it was fine. I didn't break any trim when doing this. Also remove the aircon control unit (2 screws from below, above where the cupholders are), and when you are inserting the RNS510 into the slot, you can help by pulling the extra cables away from behind the RNS510 using a hand in the aircon controller slot.
    Took two hours...removed the RNS, heater controls, stereo 'cage', drivers side end of dash, side pillar and roof lights.
    Removed older blue tooth unit, and installed latest VW one. Noting the need to cut the red and black wires which loop the mic in / mic out on the RNS wiring harness, as I wanted voice control which means wiring the mic into the RNS and then wiring the RNS mic out into the Bluetooth.
    The most troublesome parts of the job were removing the side pillar to run the mic cable .... It's very tuff and should be pulled in a direction parallel to the front window...ie accross the dash, NOT towards the drivers seat.
    The 9W7 comes with three lugs which stick out and make squeezing it and a metre of extra harness cable back into the dash pretty tight, so i cut the soft plastic lugs off and that gave me some room to move things around in there
    Plugged climate control wiring back in and RNS wires to do a quick test before putting the units back, tightening the torx screws and putting the trim back....all good.
    2 hours, couple of cuts (minor) on my fingers and hands.
    My tips - 1. read the forum, 2. buy those blue trim removal tools so you don't leave marks on the dash trim when taking them off, and 3. wrap the Bluetooth in rubber or foam around the edges so there are no plastic squeaks when you sit it inside the dash.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Jan 2011
    Mate,
    Glad to hear it all worked out.
    You forgot to mention that you saved a stack of cash doing it yourself, you learnt something new and now you can spend the money you saved on something else shweet for your ride.
    2010 Polo GTI - 5dr Flash Red
    Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
    Planned upgrades: Amp, 3 way speaker install
    Planned mods: APR tune, Brembo brake upgrade
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by 77kw polo TSi View Post
    Ah yes that's a really good tip actually. The other thing I did was shorten that ridiculously long harness by cutting and re-soldering the wires (they are individually colour coded). It fits fine when it is long, but I find it neater this way Enjoy your new bluetooth!! I know I do.
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    I am - I hate cluter - so having no visible 'after market' mike glued to the window makes me smile, and the fast start up / connect, and proper sync to my iphone 4 contacts makes me
    Next goodies- got to be those DRLs
    May 2011
    Melbourne, Vic
    Hi,
    What size HDD is in that particular rev D unit you bought and what is the production date of it?
