Mine is only a guess, but I would say, no - at least, not for daily driving ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
The standard ones are 215/40 17 right??
rolling diameter about 603mm
If you want to use a 255 on the back, it will have to be a 30 series tyre to get you close the right diameter (too large though still, by about 15mm id say)
for the 235 a 30 series will be about right.
Both of those will be expensive I'd say.
Theres no way the 255 being wider and larger in diameter will fit in the arches properly. You'd have to run a much narrower tyre to have any chance.
I would guess a 225/40/18 would have a better chance to fit, but ofcourse will be very stretched.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
