Results 11 to 20 of 23
Thread: Retro fit a climatronic
    Apr 2011
    Quote Originally Posted by pologti18t View Post
    I could have sworn the GTI comes with Climatic. You set the temp but need to adjust the rest (fan speed, vent outlets)
    The GTI comes with Climatic, which means you need to manually set temperature, fan speed and vent outlets.
    http://www.eaglehawk.com.au/images/PoloGTI/Polo16.JPG
    I gather that changes when you option the Comfort Pack...
    Apr 2011
    South Africa
    I was wondering the same thing - perhaps the best thing to do is to use ETKA and compare the aircon systems component by component... If you have climatic (semi-auto type) I'm quite positive one of the two sensors is already installed in the dashboard.
    What controls the vent position (face, feet etc) on the Climatronic? Surely that will be missing on the Climatic/Manual system.
    Apr 2011
    South Africa
    That's a very good point - on the climatic this is done mechanically (via cable), whereas I suspect that climatronic does this electrically like in a Golf 6.
    Jun 2011
    South africa
    Although I have climatic I can hear a motor working in my polo 6r when I select air distribution. Mechanical switch with electric control?
    Apr 2011
    South Africa
    Uh, I think the vent position (i.e. feet, face, windscreen, etc) is mechanical, judging on the sound and feel when changing the setting. Perhaps I need to check this again when I get my car back.
    On the other hand, the air recirculation setup is definitely electric, I remember hearing a motor when I push the recirculation button on the climatic controls (next to AC)...
    Jul 2011
    South Africa
    Would have liked have fitted this but there is just to many questions around how the manual and auto systems work.
    Apr 2012
    To my knowledge just to purchase the unit it's around $800 AU... which is also ridiculous,.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Jun 2008
    Ringwood, Victoria
    Wow, thread resurrection!
    Apr 2012
    Yeah I've been getting bored of the current ones...lol
