I still think it’s worth considering that insurance company might reject your claim if they discover you had non-standard size tyres fitted.
We can agree to disagree, that's cool. But if you want to have some fun ask the TMR if you can "run a 215/45/17 with a diameter of 625 mm if your car originally comes with 215/40/17 with a diameter of 628 mm"?
It doesn't matter what size is stamped on the tyre 'cause that's not what the regulation says, it's the actual diameter that makes it legal or illegal.
Gary
Ben
2015 Polo GTI & 2019 Golf R
OK so getting back on thread, what is everyone recommending to replace these Bridgestone MY02 215/40/17 tyres with.
I was happy with the ContiContactSport2 that the VW came with but was just wondering if there is another option that others are finding worth a look.
cheers
Michael
Sword Dude
2011 77 TSI Polo manual Flash Red with Sport Pack
2014 (MY15) 125 TDI Superb Outdoor 4x4
Try the Bridgestone Potenza Adrenalin RE003, they are doing a get the 4th tyre free deal at the the moment (Buy 3 tyres and get the 4th free November to 2018 Specials).
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Can you please post the part of the ADR that says diameter can be plus 4% because i have just read it and can only find 4% referrring to width.
It would be common sense for tyres of the same size to be a very close match in diameter or why bother having regs and sizes We should just chuck aything on and to hell with tyre placards
In the meantime I have asked TMR to explain the rule about diameter to me so await a reply
6.1.5. Tyre outer-diameter specifications
The outer-diameter of a tyre must not be outside the values Dmin and Dmax obtained from the following formulae:
Dmin = d + (2H . a)
Dmax = d + (2H . b)
where:
6.1.5.1. for sizes listed in Annex 5, and for tyres identified by the "tyre to rim fitment configuration" (see para. 3.1.10.) symbol "A", the nominal section height H is equal to:
H = 0.5 (D-d), for references see paragraph 6.1.2.
6.1.5.2. for other sizes, not listed in Annex 5, "H" and "d" are as defined in paragraph 6.1.2.1,
6.1.5.3. Coefficients "a" and "b" are respectively:
6.1.5.3.1. Coefficient "a" = 0.97
6.1.5.3.2. Coefficient "b" Radial, Run flat tyre Diagonal and Bias Belted
for ordinary
(road type) tyres 1.04 1.08
6.1.5.4. for snow tyres the overall diameter (Dmax) established in conformity with the above may be exceeded by 1 per cent.
The tyre size labels on cars are an ADR requirement and the dimensions can (and do) vary according to that ADR. The limiting of actual dimensions is uniquely a Qld thing, I haven't noticed it for other States, they stick to the ADR's.It would be common sense for tyres of the same size to be a very close match in diameter or why bother having regs and sizes We should just chuck aything on and to hell with tyre placards
I'm genuinely interested in the reply, I asked a NSW RMS Inspector friend of a friend at a race meeting last weekend and he laughed at the dimensions requirement. Pretty much said the same as I did, it's technically unenforceable.In the meantime I have asked TMR to explain the rule about diameter to me so await a reply
Not that it snows in Qld much, but how do they handle snow tyres that are allowed to be 5% larger in diameter? Probably similarly applies to most of the off road 4WD's, particularly the beach drivers, they use much larger diameter tyres.
Gary
Here is the reply from QLD TMR which says you are wrong as the 4% DOES NOT APPLY TO DIAMETER
The limits of 15mm larger and 26mm smaller are documented within VSB14 – National Code of Practice for light vehicle modifications and applies to passenger cars of category MA.
The 4% rule that is documented within ADR23 applies only to width. The ADR"S are applicable nationwide
To understand the overall diameter tolerance allowed, you could use one of the many online tyre size calculators to understand the difference or refer to the Australian Tyre and Rim Guide for further information.
From the information you have provided, and using the ADR23 calculations to calculate, a tyre designation of 235/45/17 would have an overall diameter of 643.5mm.
Storm in a tea cup I reckon. If you are that worried that going a smidge above the recommended tyre then how do you even leave the house in the morning. Do you follow every speed limit all the time, do you have a burbly cat back that they could say is a power mod, have no flash tune loaded, wont go near aftermarket bushes or an alignment that pushes the angles a bit beyond what the factory suggested, have a non standard DV that would be classed as a power mod? Do you measure your tread depths and buy a whole set at only the whiff of a tread wear indicator coming up. Do you go above the recommended tyre pressures to give it a bit more side wall for spirited driving? An insurance company could probably pull you across the coals for all of those things if they were prepared to pull you up for going up an aspect ratio size up in a sensible tyre choice. If you are that worried about the repercussions of the tyre size suggested then I assume none of that other stuff I've mentioned is done to the car either. Each to there own but I say live life on the edge if that's the cliff we are talking about.
