Remove grill (4 screws then pull outwards).
Remove 4 screws inside each of the front wheel wells along with (i think) 7 screws on the underside.
Pop the sides out and pull the bar forward it should pop out (there maybe 2 more screws in behind the grill area into the rad support, can't remember) then you have to remove the waterlines to the headlight washers.
Take your time and don't get over agressive with it.
