Results 1 to 4 of 4
Thread: Remove Polo 6R Rear Seats
    May 2012
    Firstly there is a little black cover at the rear between the two halfs. You will need to pull out the top boot floor
    Remove this and then remove the torx bit under it. It's a t25 from memory maybe bigger. Then remove the black bracket held by the bolt.
    Once you have done this you need to tilt the seats forward and you will see where the seat are held at the side
    you will need to use a screwdriver and roll the inner tab back then the seat will lift up.
    If you want to pull them out you will need to disconnect the centre seat belt.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Sep 2009
    Pretoria, Gauteng, South Africa
    Awesome! Thanks so much. Will do this tonight/tomorrow night! Thanks a million man!
    DISCLAIMER: Prices displayed in my posts are South African VW agent prices and should not be used for comparison to Australian VW agent prices.
    Jun 2008
    Emerald, Vic
    Spot on.. I just did the same.. When u put them back on the black clip can be a bit stubborn but it does eventually go back on , just needs some convincing
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
