Results 1 to 10 of 19
Thread: Rear Window Wiper Noise and Stuttering
    May 2013
    Hi
    The other day I used the rear window wiper in the rain for the first time on my Polo Trendline.
    It made this annoying noise as it jumped and stuttered across the window. So my first question is, has anyone else had this experience?
    I contacted the VW dealership and had their technician look at it. He said he cleaned the rubber on the wiper and topped up the washer fluid with Windscreen Cleaner Concentrate.
    What I don't understand is, why would topping up the washer fluid stop the stuttering and noise? I'm not supposed to constantly spray the washer while the wiper is on, am I? Also, wipers are used in the rain, so any washer fluid acting as lubricant would be washed away anyway, wouldn't it? Or am I missing something?
    Are there people who've had the stuttering wiper issue resolved by using Windscreen Cleaner Concentrate?
    Thanks in advance for any insights.
    Goz
    Sep 2012
    Perth
    After first putting some Rain-X on my front windscreen, the wipers did the hoppity thing the first time I used them (since settled down OK). Is it possible you have some product, whether polish, wax, cleaner etc, that has got smeared on the rear windscreen? Maybe try to give it a thorough clean with something alcohol-based. Even stuff you can't see with the naked eye can sometimes cause these sorts of problems.
    Now gone.... 2012 Skoda Fabia RS
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Goz View Post
    Going back to 1979 when I bought my Torana while working for the NSW Department of Motor Transport, this was exactly the same "fix" put forward by Holden in their service bulletin on the problem.
    First was to suggest the owner wash the windscreen to make sure that it is clean.
    Next suggest the owner buy and use the AC Delco washer fluid concentrate.
    Next suggest that the owner replace the wiper blades.
    Next offer to sell the new style wiper blades if the owner returns with the same problem after doing all of the above.
    It is standard operating practice.
    As to what may be causing it? It could be that the blades have hardened over time and need replacing.
    Jun 2008
    Ringwood, Victoria
    Replace the blade with natural rubber. Also clay bar and the wipe the glass down with isopropanol to remove any contaminants. This should help for a period of time but due to limited use, a rear wiper will deteriorate quicker than fronts.
    Jul 2012
    What Gav said.
    This can happen on any car and is not unique to VW, nor is it unique to back windows.
    The best way to fix is to properly clean the glass, and if you're noticing issues when it rains, then yes, spray some wiper fluid (which should contain cleaner concentrate) to clean and remove the gunk that builds up on the back window.
    And since you don't use your rear wiper much, the rubber they use has a tendency to dry out - especially if you've never used it before.
    Jun 2012
    Christchurch, New Zealand
    I had a similar problem with my front wipers after applying Rain-X. It was the first time I'd used the product and I thought I'd applied it per instructions, but first time out in the rain and the wipers stuttered appallingly. Long story short, I have since found that - in my experience at least - if you apply this Rain-X, you need to polish the bejesus out of the glass and finish off with a really dry clean cloth. Then it seems to work without any stuttering, but if you just squirt the stuff on and give it a relatively quick wipe off, it causes issues.
    Maybe it's just me, but I'm not yet convinced on the merits of these types of products.
    Mar 2011
    Wollongong
    I used to swear by rain-x in my air-cooleds. 30 years of wear and loss of spring tension meant those wipers were pretty useless. or perhaps they were useless to begin with. With rain-x I didnt often use the wipers. The heavier the rain the better it worked. Only time I needed the wipers was when it was really fine mist. Maybe the near vertical windows made it more effective than on the polo? Wind hits it harder?
    Aug 2012
    Geelong, Victoria
    you are not meant to use the Wipers after using Rain-X
    Quote Originally Posted by Rubbadub View Post
    Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
    APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
    Plus a few other bits and pieces.
    Sep 2012
    Perth
    Quote Originally Posted by steveyoshi View Post
    In light rain, of course; full-on torrential stuff, I don't think so.
    May 2013
    Thanks to everyone who replied, this helps a lot.
    So stuff on the window and wiper can cause the stuttering and need to be cleaned off. This I understand.
    Someone suggested the rubber might have hardened. But this car is brand new! Got it about a month ago. So the rubber on the wiper should be new as well, shouldn't it?
    I'm having a bit of difficulty getting my head around the comments that suggest the rubber tends to deteriorate (harden, dry up) faster on the rear window wiper because it is not used as often as the ones in front. Would using the rear wiper more frequently, that is any time I'm using the front wipers, make it last longer, or make the stuttering go away?
