You will need the straight pin i.e. BA15s;
Bold-Sport.com :: RED LED Brake Lights (Polo 9N)
I bought CREE's because most LED's are less visible than standard bulbs. The CREE's are seriously 3x the light output than standard bulbs!
Keep me posted how you go, I was also going to tint the centre light! I really wanted to replace it but that requires wing off job
So tinting it is!
Also, VLEDS for resistors if you decide to go down that path. I bought them with metal casing covers so it won't melt anything.
So to everyone following this thread; if you buy these black tails, it doesn't have a red shield over the brake section which means you've got to add a red bulb. Standard red coated bulbs turn out pinkish, so the easiest solution is to go with an LED (BA15s).
LED's will give you issues, such as the light slightly pulsating (error-checking) and error out on dash (can code this out though), but won't solve error checking (pulsating). If you decide to add resistors, you'll need a 6ohm 50watt load resistor (what I've discovered anyway) (PM me if you'd like to do indicators too) on each rear harness side. I've got pictures later... You need to attach this via the second and third wires (looking top down) which is for the brake light circuit.
All the best everyone!
