bizarre - initially you'd think that if the exhaust was hit then it was pushed up into the motor and it's cracked at the manifold somewhere, which would explain the fumey smell that got worse. Driving it around with a cracked manifold will make it crack more. Pushing fuel up the overflow pipe is bulls*it because we always have fuel going up the overflow pipe, that's what it's there for...
Cracked pistons and bent sparkplugs - were there bent valves as well? if the timing chain skipped some teeth or the tensioner has fallen apart, then the pistons will hit the valves and you get catastrophic failure, but if that happened during the accident then it would have been DOA at the repairer.
What gearbox do you have? manual or DSG? if it's a manual and you were stationary, it was either out of gear, or in gear with the clutch depressed. In either case, the fact that the car was pushed forward could not have any impact on the motor. However, if you have a DSG it might be a very different story - the sudden acceleration through the 'box might have done something to basically overrev the engine from standstill, that may make a mess of the timing chain tensioner assembly. If the tensioner assembly was damaged in the accident, then it's possible that it was OK for a week or so then fell to bits... But realistically, the chances of that happening are very low, and very difficult to prove
I reckon your car has had it - I'd get a second hand motor from the wreckers then sell it - preferably as a trade-in so you don't have to look the poor b*stard who is buying it in the face...
