Results 1 to 5 of 5
Thread: Rear disc brakes - piston wind back tool
    Sep 2008
    Rear brake piston wind back tools - what a minefield.
    Seemed a waste to pay$30 to $300 for a tool that gets used once every several years.
    So I ended up with a <$15 Toledo brake piston cube from Total Tools. Doesn’t quite fit out of the box but a little reengineering and it worked fine.
    Plenty of brands offering the cube that appears a copy of Lisle 28600. Mostly selling for $20-40.
    28600 Disc Brake Piston Tool | Lisle Corporation
    But even Lisle won’t tell what cars or calipers it fits - mostly USA brands and some imports.
    Toledo says its tool is aluminium, but it is rather heavy and magnetic! Looks to be cast stainless steel. Aliexpress models say carbon steel — if so must be plated to stay shiny. Will know more when it rusts.
    The four prong side is closest for Polo 6R/C rear brake pistons. Have to cut or grind off two of the house shaped prongs. Could be made to fit better with more grinding of height and inner bevel. But at least it has flat sided prongs compared to nearly all the generic kits that have round prongs.
    Shared album - B Louis - Google Photos
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
    This is the kit I have which ive had for about 8 years now, has worked on all cars ive used it on: Schwaben - PBK-11PCS - Brake Caliper Piston Tool Kit - 11 Pieces
    Mar 2017
    Tasmania
    Heresy! Quality tools are never a waste of money
    The toledo one is probably just cast steel, electroplated with zinc. Pretty common manufacturing method.
    Sep 2008
    Quote Originally Posted by doc_777 View Post
    If i need a better tool, one with 3/8” drive that takes a specific disc would be my quality choice. https://m.aliexpress.com/item/100500...2214b6a&gclid=
    But one of these for vw would be enough...
    https://www.repco.com.au/en/tools-eq...198/p/A9445106
    Sep 2008
    The Toledo cube is made in Taiwan.
    Monotaro sells one similar made of chrome moly steel. So I suspect the Toledo one is chrome moly too.
    Lisle, SnapOn, Beta are flogging the chinese generic kits.
    KTC Japan makes 3 double sided discs that fit 6 different styles and lists brands they are supposed to fit. ABX104 fits VW and Audi.
    ディスクパーキングツールセット[3コ組] | KTCツールオフィシャルサイト
