1.Use the instructions in this forum for RNS install its pretty much the same except you dont need to install a GPS antenna. (its so easy took me like 15minutes)
2. no its all automatically activated
3. no one wants RCD310s i still have mine sitting on the floor next to me
4. yes once you plug in the RCD510 you need to enter the security code make sure the sseller provides it
5. your car wont have the MDI so youll have to either retrofit the MDI, use the existing AUX cable or fit bluetooth and then stream through bluetooth
