Hi guys,
I've got a MY12.5 90TSI with park assist, would it be the same to installing the RCD510 plug&play without any configuration?
As my current RCD310 has a visual display of the parking sensors when I'm reversing/parking.
Hi guys,
The RCD 510 would need to be coded to accept the input signals of the OPS system, yes.
On a VCDS system. You will already have the OPS system activated in the coding but you would need to have a look in the radio control module to see where in the adaptations you would need to activate it. Sorry if that sounds confusing but with the VCDS system in front of you, it would make perfect sense![]()
I've done this twice on a MkV Golf, and the whole top section of the dash/vents/etc needed to be removed.
Amazed at how simple the process is on the 6R - just one piece of trim!
2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
Did this today, couldn't have been easier, BT streaming is now has CD-like clarity![]()
