Results 21 to 30 of 33
Thread: RCD510 install pics
  1. #21
    Aug 2011
    Quote Originally Posted by tuan0011 View Post
    I have factory bluetooth, does anyone know if changing to this unit will affect that?
    Should be all fine with the bluetooth, just plug and play when it comes to factory installed stuff.
  2. #22
    Oct 2011
    Botany
    Hi guys,
    I've got a MY12.5 90TSI with park assist, would it be the same to installing the RCD510 plug&play without any configuration?
    As my current RCD310 has a visual display of the parking sensors when I'm reversing/parking.
  3. #23
    Aug 2011
    Quote Originally Posted by calebo View Post
    Hi guys,
    Yes all should be well, just make sure you get a newish RCD unit built around 2011/2012
  4. #24
    Jun 2008
    Ringwood, Victoria
    The RCD 510 would need to be coded to accept the input signals of the OPS system, yes.
  5. #25
    Aug 2011
    Quote Originally Posted by gavs View Post
    My bad I forgot that it still needed to be coded into the unit and that it doesn't just use the Cent Elec. Installed list.
  6. #26
    Oct 2011
    Botany
    Where can i find more info on doing that?
  7. #27
    Jun 2008
    Ringwood, Victoria
    On a VCDS system. You will already have the OPS system activated in the coding but you would need to have a look in the radio control module to see where in the adaptations you would need to activate it. Sorry if that sounds confusing but with the VCDS system in front of you, it would make perfect sense
  8. #28
    Jun 2012
    North Sydney, NSW
    Hi guys,
    I just replaced my RCD 310 with a RCD 510 and the park assist/OPS system works perfectly on the RCD510 display, no coding required was just a straight swap. However my AUX has stopped working ( all activated in VCDS), thinking it may be a wire issue??
  9. #29
    Jan 2008
    I've done this twice on a MkV Golf, and the whole top section of the dash/vents/etc needed to be removed.
    Amazed at how simple the process is on the 6R - just one piece of trim!
    2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
  10. #30
    Aug 2011
    Did this today, couldn't have been easier, BT streaming is now has CD-like clarity
