Hey there OUR6R
1. Do all rcd510's have GPS and is there a GPS antenna or module required or is it inbuilt?
RCD510's Don't have GPS capabilities, the RNS510 does. In the event you buy the RNS510, if your car has the shark fin antenna, there will be a provision to hook the GPS up the that, otherwise, no the antenna will be external and on a wire.
2. Is the wiring / harness and plug set up in the 2010 6R compatible / plug'n'play with the rcd510?
Yes RCD310 to 510 is plug and play, you may have to do some VCDC coding or have a CANBUS mod depending on the model of your car
3. I'll also add a Bluetooth module, is there a particular BT module for the rcd510?
9W7 I believe is the bluetooth module, Depending again on the model of car, presuming you have a Polo 6R with a touch adapter? if you have a touch adapter, you already have the 9W7 Bluetooth base, all you'll need to do is code out the touch adapter. if you have no bluetooth at all, the setup is slightly more complex and will require some further hard wiring.
4. While searching the forum I've seen people ask about the "FD" number. Is this relevant and is there an FD number I should be looking for?
Not sure what an FD number is. In saying that, I know you want the Bosch variant of the RCD510, these work best with what you're trying to do.
There are heaps of threads on upgrading your 310 to a 510, also read about the touch adapter and bluetooth thingo by Illogitech.
Luke
I Sell Nissans Skodas.
IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
