Results 1 to 7 of 7
Thread: Radio question (presets)
    Apr 2008
    Blacktown NSW
    One of my preset radio stations has lost it's name, and is only showing the frequency.
    This happened after I changed some of the stations that are preset.
    Is there a way to bring back the name of the station, as all of the other presets still show the name and that is my preference.
    It is a RCD 310 radio.
    Thanks
    Pacific Paradise QLD
    Quote Originally Posted by parraeel View Post
    Thanks
    Not being rude but have you looked in the manual Mine only shows the frequencies .
    Mar 2013
    Brisbane QLD
    All vw radios show station names now even the basic 310...some times if the frequency is out by just 1 it will not put the name up even tho it sounds ok....VDUB....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2011
    Things to check:
    -Make sure you have radio text enabled in the options menu
    -Make sure you are in the city/have good radio reception
    Then try tuning to your frequency and pressing and holding down the preset button you want to save it in. Could be when you saved it it couldn't download the radio text and the radio name couldn't be saved in the preset so the frequency was displayed instead.
    I have had this a few times. Hope it helps.
    Aug 2011
    Quote Originally Posted by nomadx38 View Post
    Things to check:
    Yep its that, make sure the radio text has loaded before setting the preset
    Apr 2010
    Just manually scroll to the frequency in question and hold down the preset button for a few seconds to reset it - should force it to lookup the station name if it is being broadcast and you are in a good reception area.
    Apr 2008
    Blacktown NSW
    All good now, thanks everyone
