Results 1 to 10 of 20
Thread: Quick MDI question
    Mar 2011
    Quick MDI question
    Apologies in advance for the rookie question.
    I got the MDI fitted by the dealer before I purchased the car, works a treat and looks fine but I seem to be having a problem with the balance through the MDI, the sound is crystal clear when I play tracks from CD but when I go to play the same songs through my ipod the vocals are almost completely non-existent...Anyone good with this stuff know if its fixable?
    2010 Polo GTI 5dr, reflex metallic silver, MDI.
    Now Replaced With
    2012 Polo GTI 5dr, Candy White, Sunroof, Detroits
    Oct 2010
    Essendon, Victoria
    Definitely seems like a connection issue. Take it back to the dealer and ask them to re-check the MDI connector and that the pins are correct and making contact. I had a similar problem when I installed an iPod module to my C4, it was found that one of the pins was incorrectly crimped to the connector block.
    2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
    MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
    Quote Originally Posted by Miles Away View Post
    Hey Miles Away, how much did the MDI cost? Also another question, can't you just use the function that comes standard with the GTI to hook up your ipod? (forgot what it's called)
    2011 Polo GTI - Reflex silver, metallic. Ordered 29th Jan, received 8th Oct.
    Apr 2011
    Sunshine Coast, QLD
    The Media Device Interface is NOT standard on the GTI, but comes with the Audio package. If you want the iPod to function through the RCD 510 touch-screen radio/cd player/sd card reader/ MDI I believe you need an iPod cable, which is a sold separately.
    On another note, I'm angry that the radio will NOT play music downloaded from the Apple store or imported from a CD via iTunes as "Apple Lossless". But I don't know who to be angry with... VW, Apple or both... Aargh! Got to re-import (or convert) a large selection of CDs into a standard format. Aargh!!
    Dec 2010
    What do you mean exactly RoknRob? Do you mean it won't play it via an iPod or on an SD card?
    Polo 77TSI Comfortline with Sports, Audio, Comfort Packs in White.
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Gladiator View Post
    Do you mean the aux in jack mounted below the HVAC controls in front of the gear selector? That should work but it kind of removes the point of the MDI, the AUX in is basically a headphone jack. MDI gives you integration and functionality.
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by themmc View Post
    That's exactly what I mean. I bet if I had a data cd with those files it would be the same problem. The weird thing OS it is not all my files, but a lot of my recent ones.
    Another possible solution is to buy a Bluetooth module and stream the files from my phone. That's not gonna happen for a while for me...
    Quote Originally Posted by RoknRob View Post
    This is not good at all! The only reason I opted for the audio package was for complete iPhone/iPod integration. I just want to "plug and play" and forget... I'll be watching this space with interest....
    MkV GTI Pirelli | APR tune
    Apr 2011
    Sunshine Coast, QLD
    I think that will be different. If your iPod is connected through their proprietary cable, your iPod will be doing the decoding, so all iTunes files should work.
    I think...
    I don't own an iPod, nor a special cable, so I can't confirm. I was glad you could get that iPod functionality with a cheap SD card or USB stick, instead. Not as easy as I had hoped...
    Oh, you're referring to the SD card slot. Yeah that is a shame. I imagine the RCD510 only likes the usual MP3/WMA files types.
