Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Polo tsi --> gti spring install
    Aug 2012
    melbourne
    Hey boys, just a quick one.
    I have a 2012.5 TSI, stock.
    Would like to correct the 4x4 height at the rear.
    I bought some near new 2016 Polo GTI springs.
    Now, ive read the GTI springs are too harsh for some, but im thinking its because of the low sidewall and bigger wheels.
    I have stock tyres 185/60/R15 i believe, so maybe the ride will be bearable on my tyres?
    Does anyone know if the GTI springs will lower the ride height much?
    Or will it be almost the same just firmer + stick to the road more?
    Got a service coming up in 2 days so any help before then would be great.
    Thanks in advance.
    J.
    Apr 2015
    Being a pessimist, how many K's has the car done? From memory the GTi was 10/15 mm lower than the TSi and common spring settling is around 3 to 5 mm in the first 5,000 k's then 1 mm or so for each 10,000 k's after that, depending on load of course. That happens up to around 60,000 k's at which time the original shocks are commonly past it and can no longer control the spring oscillations. This commonly results in spring fatigue which can often accelerate the settling. So, if you put, say, a new pair of GTi springs in a TSi that has done say 60,000 k's then it is quite likely that they won't lower it much at all. Plus of course the shocks will be past it, keeping in mind that they weren't valved for the slightly higher GTi spring rates in the first place. Of course the higher spring rates will accelerate the shocks' deterioration.
    Again from memory the GTi springs only have about a 10% increase in their rate, so I'm not even sure that, ignoring the above, it's even worth the effort to swap them if improving the handling is a consideration. I'd be far more likely to recommend a rear swaybar, that would make far more of a difference.
    Having swapped wheels & tyres from a TSi to a GTi Golf I can answer the second question with a most likely yes, the lower profile tyres make more difference to the ride comfort than the slight difference in spring rates.
    Gary
    Aug 2012
    melbourne
    Thanks for the reply.
    My TSI has done 50,000ks
    The GTI springs not sure, but couldnt be more than 30,000 as the car was relatively new then, theyve been lying around waiting to be put on.
    I would put aftermarket springs in, but i like OEM and i already have these so im tempted to try them on. If the shocks need changing soon anyways, so be it. The car is rarely driven nowadays so its more of having it sit right and still be comfortable and practical.
    Sep 2016
    I'm new to my 2015 Polo and was reading about the optional sports pack and luxury pack after getting the car, not that I was wanting to spend more on it but the I read the sports pack has lowered suspension. How low it is I'm not sure.
    If you want more lowered then you will need aftermarket shocks and springs.
    A crappy method people want low is to cut a coil off the spring for the low look, its more for show and does not do anything good for the car.
    Apr 2015
    Quote Originally Posted by MRZ View Post
    I've not heard about a "sports pack". I thought the choices were "Luxury Pack" which includes LED headlights, a panoramic sunroof and comfort sport seats with black Alcantara inserts. The other is the "Driver Assistance Pack" which features satellite navigation, parking sensors and driver fatigue detection System.
    From memory the GTi is 10/15 mm lower than the non GTi models, packs make no difference to the height.
    Gary
    Aug 2012
    melbourne
    Quote Originally Posted by Sydneykid View Post
    Gary
    I got those Alcantara Seats installed in the TSI and i absolutely love them, if i remember correctly it was like a $4000 option for that pack.
    So 15mm huh. its not a lot but maybe worth a try so see how it sits. I've measured the height its at now and ill do before and afters.
    Not sure about this because im pretty sure the rears are not straight coils theyre egg-shaped coils so small-big big-small on the ends.
    I've cut springs before on old commodores and anything over half a cooil or so and the ride starts to get bouncy - I had someone smack their head on the roof once lol danger
    Sep 2016
    I haven't looked into the "packs" that much but here is the article I read on the Polo with the mention of "Sport Pack" 2016 Volkswagen Polo Review | CarAdvice
    15mm drop really aint much, a couple case of beers in the boot will probably drop it that much LOL.
    Aug 2012
    melbourne
    Checked out that article, mannn there is some tension in those comments, a lot of arguing going on.
    Anyways those wheels on the latest Polo Comfortline are very nice, whatever they are called great design, maybe a set of them (if 16" and over) might be worth buying to bridge the wheel to fender gap. You're right about the weight on the rear, I might try placing a small weight in the "hidden storage" to get some spring sag aswell.
    Apr 2015
    You're right, the non GTi models have a "Sports Pack" option as well as a "Driving Comfort Package".
    Gary
    Mar 2011
    Wollongong
    In 2012 there was comfort pack, sports pack for the tdi/tsi.
    comfort pack has climate control aircon, auto dimming mirror, tyre pressure sensor, rain sensing wipers.
    sports pack has boavista wheels, tinted windows, front fogs, tyre pressure sensor, nominally 15mm lower springs.
    From memory I think comfort was $600, sports was $1500. Both worth the money IMO. No you didnt get a discount if you got both, you pay for tyre pressure sensor twice. Its the least desirable inclusion, kinda useless. You dont get a warning until it drops to about 18psi. I guess its more of a puncture warning than a maintenance due warning. By the time pressure gets that low its pretty obvious anyway. I dont know whether its because I have stopped looking after 4 years or if it has settled, but from new, I still thought the rear was too high even with the sport springs.
    I dont know if its wheels and tyres or springs, but the sport pack makes the ride quite a bit firmer than the standard tsi I test drove. Unless you're cruising the worst of Sydney roads then it isnt that bad. If its too firm you should buy a camry.
