Stalking this thread)
No I've one already, 6Rtsi 77kw 6M, and am wanting to open it up a little. It's my daily, and fun to drive, but I find it far to slow... However it's a torquey(?) little motor, which is very enjoyable in the tight corners and hills, of GC hinterlands.
Spose it depends on previous experience but I think it does need another 30kw or thereabouts
^ you wont find another 30kw because the turbo on these is just so small and was never meant for performance. The intercooler is also a limiting factor as its moulded/part of the inlet manifold so its both very small and not very efficient. An intake setup, some sort of 2.25" dump pipe and a tune would be about all you could do. Perhaps water injection might help the intercooler out and free up a little more power (and help make the power consistent).
Cheers Lucas_R,
Yeah seems it's set up toward the fuel economy side of things...it is a very innovative engine, a lot of plastics, amazing bits of technology. I reakon water injection is a spot on solution too, the stale heat just above the bitumen saps a lot of power, the difference between 1pm and 1 am is phenomenon out where I live. But probably getting a bit to serious for a DD.
No point unless you want to change lots of plumbing and upgrade the IC as well. You'd be better off starting with water injection or as it's a water/air IC try & lower the cooling system temps somehow
Heard on the grapevine APR are releasing a tune for the 1.2 shortly
