Results 11 to 20 of 24
Thread: Polo tsi 77 chip tune
    Jul 2013
    118tsi is a lucky dip - maybe you get a good one, maybe not. Polo GTI is the same engine/trans - maybe good, maybe not.
    Golf GTI is good. Skoda 118tsi good (1.8tsi turbo only), Skoda Octavia vRS is good. Fabia vRS same as polo GTI.
    Thanks for the heads up I don't want any trouble and having to fiddle around with my car constantly I might have to look into the older polo GTI now they are pretty reliable
    Nov 2010
    Quote Originally Posted by B0nes View Post
    Do any owners think its a bit sluggish only being 77 Kw
    NO...but that didn't stop me getting a DNA tune
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
    May 2014
    Queensland
    Stalking this thread )
    Jul 2013
    Quote Originally Posted by 666R View Post
    Are you looking for a polo to?
    May 2014
    Queensland
    No I've one already, 6Rtsi 77kw 6M, and am wanting to open it up a little. It's my daily, and fun to drive, but I find it far to slow... However it's a torquey(?) little motor, which is very enjoyable in the tight corners and hills, of GC hinterlands.
    Spose it depends on previous experience but I think it does need another 30kw or thereabouts
    ^ you wont find another 30kw because the turbo on these is just so small and was never meant for performance. The intercooler is also a limiting factor as its moulded/part of the inlet manifold so its both very small and not very efficient. An intake setup, some sort of 2.25" dump pipe and a tune would be about all you could do. Perhaps water injection might help the intercooler out and free up a little more power (and help make the power consistent).
    May 2014
    Queensland
    Cheers Lucas_R,
    Yeah seems it's set up toward the fuel economy side of things...it is a very innovative engine, a lot of plastics, amazing bits of technology. I reakon water injection is a spot on solution too, the stale heat just above the bitumen saps a lot of power, the difference between 1pm and 1 am is phenomenon out where I live. But probably getting a bit to serious for a DD.
    Nov 2014
    Lilli Pilli
    ^ The intercooler is also a limiting factor as its moulded/part of the inlet manifold so its both very small and not very efficient. An intake setup, some sort of 2.25" dump pipe and a tune would be about all you could do. (and help make the power consistent).
    i personally have no idea where to start when it comes to the turbo, have you heard of anyone placing a bigger turbo in the 77kw
    Erskineville, NSW
    No point unless you want to change lots of plumbing and upgrade the IC as well. You'd be better off starting with water injection or as it's a water/air IC try & lower the cooling system temps somehow
    Dec 2013
    Heard on the grapevine APR are releasing a tune for the 1.2 shortly
