Results 11 to 20 of 32
Thread: Polo TSI 2010 problems - snapped timing belt
    Erskineville, NSW
    Quote Originally Posted by bushman View Post
    Does moderator or anyone know if this was a mandatory change by dealer during warranty period, as most of these will be out of warranty now ? Because I know mine was not replaced, although not showing any symptoms but for tiny rattle
    It's not a mandatory change. You've got to have the noise. It's usually most prominent when the oil is cold. VW rarely carry out pre-emptive fixes.
    kar2390 - isn't that the TSB in post 4?
    Mar 2014
    Mernda, Victoria
    Oops my bad, I tried opening it but for some reason the image wasn't very clear. It was fine after I saved the image to the device.
    So just wondering if a VW dealer would know the type of chain tensioner my car has installed at the moment. Also does anyone have an idea what this would cost.
    Jul 2012
    Sinagra, Western Australia
    Vw can tell by the engine code if it falls into the range. You would be looking at between 4-8 hours labour to get it done.
    Apr 2013
    Melbourne,vic
    Bring it to Burwins we will fix it
    Mar 2014
    Mernda, Victoria
    Quote Originally Posted by Snail Style View Post
    Thanks for the info Snail Style
    Quote Originally Posted by Pokie View Post
    Cheers Pokie thanks for the offer, do you get a lot of 2010 models coming in to get them done
    Erskineville, NSW
    Quote Originally Posted by kar2390 View Post
    Between $900-$1200 if the EA888 fix is an indication.
    You really want to push to get this done under good will. Take a copy of the TSB. It will cost you about $150 to get a diagnosis done (refundable if they find a fault).
    If they say it's normal, escalate it to VW Customer Care. If that is a dead ed then make sure you have something in writing that says you were concerned about an engine rattle from the LHS at start up & that VW couldn't identify a fault. It might give you some ammunition if it fails later.
    If you come across as being persistant they might do it just to get you out of their hair.
    Mar 2014
    Mernda, Victoria
    Ok cool thanks for the info Brad, I've taken a few videos of the car on start up. I can only ask I guess if they can repair it under good will. Checked the engine number according to the TSB and mine falls before the production of the optimised timing chain.
    Mar 2014
    Mernda, Victoria
    Hello again, I had the diagnosis done today and results came out that I require a new timing chain and tensioner, I also had them check the shuddering and was told I need a new set of clutch packs as well. They've sent a claim through to VAG requesting good will, so I should hear back mid next week. I was charged the diagnosis fee though which probably makes sense considering I haven't got warranty.
    Erskineville, NSW
    IF good will fix approved you usually get the fee refunded
    Mar 2014
    Mernda, Victoria
    Any idea how much the chain and pre tensioner costs from the dealer
