Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Polo ride height & wheel fitment thread
    Aug 2012
    Albury, NSW, Australia
    Not trying to start a battle like the golf and 9n3 lot, but just curious to know how low other polos are and what wheels your currently rocking.
    coil-overs or just springs, oem+, im interested in all.
    And if not lowered, you can still add your wheel specs. This way new comers can see what widths/ offsets work on the polo.
    Key points i think would be:
    What components you have
    The ride height drop (or range for coils)
    Wheel/Tyre size (encase of over or under size)
    Ground to arch height Front/Rear
    alternatively, follow a similar layout from the mkiv thread:
    Front: wheels/tyre size
    Rear: wheel/tyre size
    Arch height to ground Front:
    Arch height to ground Rear:
    Photo 1: showing height of car
    Photo 2: showing poke/fitment in relation to the guards
    (photos not necessary, just to show others how it all looks)
    TSI with Sports pack
    Setup: springs, 15mm drop
    Ronal Boavista
    Front: 17x7 et46 215/40/17
    Rear: 17x7 et46 215/40/17
    Arch height to ground Front: 630mm
    Arch height to ground Rear: 672mm
    (note; these heights may be wrong, was working backwards around my coil-over install and change of wheels, please pm me if you know the actual height)
    Aug 2012
    and i'll go
    Setup: coil-overs, KW V1
    Wheels: Ronal Aristo
    Front: 18x7.5 et38 215/35/18 (kumho KU39)
    Rear: 18x7.5 et28 (10mm spacer) 215/35/18 (Kumho KU39)
    Arch height to ground Front: 614mm
    Arch height to ground Rear: 625mm
    Wheels: GTI Denvers
    Front: 17x7 et46 215/40/17 (15mm spacer)
    Rear: 17x7 et46 (20mm spacer) 215/40/17
    Arch height to ground (to centre hub) Front: 597mm (317mm)
    Arch height to ground (to centre hub) Rear: 610mm (320mm)
    This is as low as I can get it with these wheels and spacers without it scrubbing out in hard cornering situations. It will still get minir scrub if hitting a big dip in the road at higher speeds (above 60k/hr).
    It is also as low as the rear coils can be wound down, there is possibly another 10-15mm if the coil adjustment is removed completely.
    Denvers:
    Aristo's (same tyre specs as mrdeathlad & no spacers)
    Oct 2010
    Essendon, Victoria
    Setup: H&R Sport Springs 25/40
    Wheels: Sparco Assetto Gara
    Front & Rear: 17X7.5 et35 215/40/17 (Federal 595 EVO), no spacers.
    Arch height to ground Front: 610mm
    Arch height to ground Rear: 620mm
    2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
    MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
    May 2012
    Polo GTI
    H&R 25/40
    OZ racing ulltraleggra 17x8 215/40 (stock Dunlop's)
    I would not go any lower with the 8" wheel as the front is dead level if not a 1-2mm out side and if the tyre wasn't stretch a little it would be nearly touching as is.
    I honestly thought the H&R springs would make it more firmer but I have felt no difference in that department. What I have found is that in reducing the height therefore centre of gravity combined with the stiffer spring type in regards to pitching over itself (side to side) there is less body roll. There's a long sweeping corner that I've been using to test on the way home of the highway. I come in at 110 and try to hold as much speed as possible without the car pushing wide. Without springs around 75, with springs over 80kmh can be held without it pushing.
    I've also changed my wheels (not rubber) to the tune of 6-7 kg off a corner which may aid this a little.
    Apologies for the crap picture. I've had my DSLR fixed and when I get the car back (2 weeks at the dealer now) will be out to take more.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Jun 2008
    Ringwood, Victoria
    polo ride height
    Great thread MrDeathLad! Please people, keep this without comment, just specs for people's reference. If I see any comments, to save from things getting out if hand I will just delete them.
    Stickied too
    Nov 2010
    Wheels: TSW Nurburgring 18x8 ET35
    Tyres: Khumo 225/35
    Arch height to ground Rear: 635mm
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
    Apr 2012
    Bridgeman Downs ,Brisbane
    Polo TSI
    Weitec Coil-overs
    TSW Mallory 5, matte black finish 17x8"
    falken RT615 205/40
    Arch to ground all round : 610mm
    best thing is no scrubbing or rubbing of any kind, even when driving spiritedly
    love it
    Oct 2011
    South Australia
    VW GTR24 or VW Motorsport Wheels as they are known.
    Standard GTI Ride Height
    17x7 ET46
    215/40 R17 Dunlop SportMAXX
    Mar 2011
    Setup: H&R Monotube coilovers
    Wheels: Varrstoen 17x9.0 ET35
    Tyres: Kumho KU31 215/40R17
    Arch height to ground Front: 612mm
    Arch height to ground Rear: (??)
