Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Polo ride height & wheel fitment thread
  1. #21
    Jul 2011
    NEWCASTLE NSW
    who is running helper springs in front and who isnt?
    im running fairly low, and im sick of the ride quality, its way to harsh without helpers.
    will having the front helpers reinstalled, and raising her up a bit soften things up? im looking at moving to a 2 finger gap, as opposed to a no finger gap.
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
  2. #22
    Aug 2012
    Albury, NSW, Australia
    UPDATE TIME!!!!!
    Gear; KW V1, rear adjusters and rubber perches out, ~10mm thread left at the front (helpers in), arch liners still in (unmodified)
    Wheels;
    Oz Racing Chronos
    Front & Rear; 17x8 et35
    Tyres;
    Nankang 205/40/17
    Arch to ground;
    Front; 575mm
    Rear; 585mm
    @mrdeathlad
    #rollinonskittles
    Shorty exhaust, black tails, Kw V1
    Ronal, Oz, Hoshino Racing
  3. #23
    Aug 2012
    check it....
    Same suspension/tyre set up as above...
    Wheels:
    Hoshino Racing Impul RS...
    17x8 et51 (running 20mm spacer for et31)
    17x9 et53 (running 15mm spacer for et38 )
    @mrdeathlad
    #rollinonskittles
  4. #24
    Apr 2014
    The Monash Freeway
    Personally I think it looks ridiculous if you lower your car so much that the curvature of the wheel arch looks significantly different to the wheel. You need at least 18s.
    Unfortunately the design of the polo is such that this means anything more than an inch is too much.
    IMHO
    Sent from my SM-N9005 using Tapatalk
    Ben
    2015 Polo GTI & 2019 Golf R
  5. #25
    May 2011
    Albury, NSW
    Quote Originally Posted by BenT View Post
    IMHO
    Get outtttt!
    That's what wheel centering plates are for.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  6. #26
    Mar 2011
    The issue you speak has nothing to do wheel size at all. It relates directly to the design of the rear bar arch which does not flow with the contour the quarter panel arch or wheel/tyre for that matter, like it should.
    So the more you lower the more pronounced the issue becomes as the wheel moves forward under the arch and therefore the gap at the rear becomes even larger.
    Does that make sense?
  7. #27
    Mar 2011
    Quote Originally Posted by nightphotographer View Post
    No can do on the 6r.
  8. #28
    May 2011
    Albury, NSW
    Quote Originally Posted by ATYPIC View Post
    That sucks - I assumed the MK4 ones would fit?
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  9. #29
    Mar 2011
    Yep it does...I was so keen fix this eyesore.
  10. #30
    May 2011
    Albury, NSW
    How different is the 6R set up to the 9N3? Mine only goes slightly off centre when I'm the lowest I can possibly go (I'm talking helpers out, bump stops cut and 3 spare wheels in the boot!) on 17's. Maybe it's the bigger arches on the 6R that emphasise it more
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
