Results 1 to 10 of 13
Thread: Polo Radio Help
    May 2012
    Gungahlin, A.C.T.
    Quote Originally Posted by readerr0r View Post
    That means if you install a RNS510, you'll be able to keep the BT and MDI already installed in the car and voice recognition should work too. Then the reverse camera can be installed later as well.
    Fantastic! That is great news - exactly what I wanted to do. RNS 510 here i come!
    Is it ok to buy one from the UK for example of ebay or will there be radio settings and things that are not suitable for OZ?
    Jun 2008
    Ringwood, Victoria
    Wow, I can't believe I overlooked that fact! GOod pick up readerr0r!
    first off, make sure you have the 9WZ bluetooth, otherwise voice recognition will not work with the RNS unit. Second, if you want voice recognition, make sure you get a european spec unit because the US ones are different.
    THird, if you want reverse camera functionality through the RNS system, again, make sure you get the european unit. It has a specific 'video in' jack on back of it that takes a 26 pin DIN plug.
    THen, get it all coded up and away you go
    Adelaide hills, SA
    Quote Originally Posted by tasguy81 View Post
    You'll be OK with the unit from UK, many members bought from there and also from Lithuania just make sure you get the latest version of AU maps and check the differences between different versions of RNS510.
    ...and welcome to the forum.
    Mindarie, Perth (WA)
    Maps (AUS/NZ) are not an issue. If you ask kindly.....there are members here who can 'lead' you in the right direction.
    Also...there should be a new map version coming out soon....*fingers crossed*
    Video In Motion (VIM), re-partitioned HDD for the RNS (more music space), customized splash screens and personal POIs are all the sorts of things we can help you with here.
