Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Polo OEM scuff plates
    Oct 2012
    NSW
    Quote Originally Posted by d_train View Post
    I got mine (5 door) from a dealer for $230. My wifey installed it because she's good like that But it was for her car and it did come with instructions.
    Makes a difference, good contrast from just stark painted metal.
    Hi,
    Was that a genuine VW part and is it shown in any of the photos I linked to? What was involved as regards the installation process?
    MY13 Polo 77TSI manual transmission Comfortline in Candy White - "Herr Marco"
    Oct 2012
    NSW
    I got 3M protective clear film and did both cars All the door sills and both boots for $150 and a days time. Can supply some pics of it
    That seems a great option since I would prefer something very discreet if possible. Though with the installation, does it cover all the way down to the lip just above where the stone proof paint begins? That actually seems the most vulnerable area to me...
    I see an Australian company sells a DYI door sill kit using the 3M film. It would be perfect and since the application area is flat and rectangular, even I could probably manage it. But the strips are 7 cm wide, which means they will do the top bit only (will have to measure the door sill today).
    Anyway, photos would be great please. Thank you.
    Duco Scratch Online Store: Clear Door Sill Guards - sedan or wagon, DIY kits for Cars
    Dec 2012
    Yes, correct. From your link, the description for it is "Door Sill Protective Strip" in the Interior section. The one with the word "Polo" inscribed on the aluminium panel.
    Instructions are from Germany, so it's quite precise But it's all about having a point of reference, and having the sill stuck on. It's one those things you take your time to do, and not rush - and the better the end result will be. But yeah, any person with average hands can tackle it.
    Oct 2012
    NSW
    Thanks. I just got off the phone from the local VW Parts department and they confirmed there are two styles as per the photos on the Phil McCarroll website. There is the aluminium scuff plate you mention plus the much wider protection which is apparently (though I am not certain) self adhesive vinyl. This is the one that covers the entire width of the sill from the rubber door frame seal right to the inside edge of the stoneguard paint.
    The latter kit is around $140. I asked him if he knew how difficult it was to fit and he said this was the first one he had ever had to order, so no one there knows exactly how it works. Given no one there has ever fitted one I wil probably just drive to my mother's house and see if she can help me fit it (she was an expert "book coverer" and "wall-paperer" in her time). So I would probably trust her to do it at least as well as a VW mechanic. But if it looks all too hard then better the dealership do it so they have the liability if they stuff it up and need another kit Apparently the approved VW fitment time for this accessory is 30 minutes for all four doors, so it is probably not too difficult if some commonsense and patience is exercised.
    Pacific Paradise QLD
    Quote Originally Posted by JonP01 View Post
    Here is what it looks like You can really only see the edges in the pics
    This is one sill Done from up under rubber to right down underneath
    [/IMG]
    This is L/H end of rear bumper down down to the bottom of the shiny spot with leftover piece I had
    This is R/H end of Passat bumper
    Drivers Door sill Passat Is in two pieces as sill strip is separate on this model
    I got it here Product Page - OziShield :
    HOW TO APPLY IT
    You need 2 spray bottles
    1 squeegee as sold by Ozshield
    The film cut to size
    1st spray bottle has water with a teaspoon of dishwash liquid in it
    2nd one has diluted isopropyl alcohol in it. $6 a bottle at Bunnings
    Clean sills with meths and dry off
    Spray sill with water solution one at a time
    Strip the backing partially off the film and liberally spray with water solution Work it down so you never touch the sticky side Drop it onto the sill and pull remaining backing out. Then move it to where you want it If plenty of water will just slide around
    If its exactly where you want it lift up a corner and spray soame alcohol under that and squeegee it down That will hold it in place
    YOU CANT MOVE IT AFTER DOING THIS.
    Working from the middle squeegee the water and air out completely.
    Make sure all bubbles are out and you are finished.
    Sounds easy Its not quite but sills are Ok as they are even The rear bumper on the Passat was a different thing altogether.
    I have enough film here and can cut it to size as on my car for $65 plus postage for you
    You also should buy some Plexus plastic polish from a motorbike shop to keep it from absorbing any water. Is about $26 a spraycan
    They look alright, hardly discreet though as you said you wanted.
    But its the bottom bit that gets the hits.
    As in my pics the whole thing is covered and goes wider across the door opening as well. Cost $50 for the 4 doors
