Page 155 of 226 FirstFirst ... 55105145153154155156157165205 ... LastLast
Results 1,541 to 1,550 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1541
    Apr 2013
    Auckland New Zealand
    Hi Guys
    Has anyone who used MotoMan's running in method experienced high oil usage? (Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power)
    Gambit, you reported no sign of oil use at 2,500km - still no issues?
    Really excited! I'm finally picking up my Oryx (pearl) white, bi-xenons CTHE GTI on Sunday after 2 months owning it and waiting till I could clear building materials from the 2nd garage. (I didn't want its stablemate Reflex TSI to have to stay outside in Auckland winter weather!) So I want to run it in in the best possible way.
    Cheers!
  2. #1542
    Mar 2011
    Quote Originally Posted by 2PoloGuy View Post
    Hi Guys
    Cheers!
    There is plenty of information to read this thread which will answer you queries.
  3. #1543
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by ATYPIC View Post
    Exactly, thank you Atypic
    RoknRob, I think you need an engine rebuild mate because my (limited already) oil consumption has literally stopped. Oil level has not moved in 5000kms of hard driving since switching to Fuchs.
    On a side note for the last 5000kms I have dedicated all driving to M and driving the car properly, not like the f**kwit software nerds at VAG hq programmed into the D program which results in idiotic shift points and limited down-shifts. Perhaps this could also have contributed to the lack of consumption, perhaps it was the tune update as well...
  4. #1544
    Apr 2011
    Sunshine Coast, QLD
    Hi Guys
    I did, yes.
    Quote Originally Posted by gavs View Post
    Thanks for the opinion, gavs - I intend to ask for another oil consumption test when they pull my car in for the recall.
    It's an interesting thought that driving in M may make a difference, but I bought this car in part because of the remarkable fuel economy, for such a performing car, and I certainly don't see that when I let myself loose!
    I feel I should get the fuel economy I paid for... I shouldn't have to sacrifice that to save on the oil... so I hope they will address this next time I go in, too.
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  5. #1545
    Jun 2008
    Ringwood, Victoria
    Mate under ADR I believe that at last consultation, the production vehicle only has to retain 30% of the componentry of the test vehicle, this is across all tests including stability control etc. which is why when we test production vehicles at work, they never even reach the requires speeds for the tests because they're nothing like the vehicles that were used for certification and as shown, why a vehicle with esc turned on can still roll quite easily.
  6. #1546
    Jul 2012
    victoria park, WA
    Hi Guys
    Brought my car in for its 5th oil consumption test now (done 10,000kms) and its still losing 700ml per 1000kms..the dealer has advised me there is second updated ventilation valve, air connection pipe and ventilation hose for the engine which will decrease the use of oil...has anyone had this done to their car yet?
    This will be the second attempt at changing the hose etc..hope it works this time as I am getting sick of having to bring it in all the time for an oil top up!
    Gavs..what exactly is Fuchs?
    Thanks
    Scott
  7. #1547
    Sep 2012
    NSW
    2200km from my engine rebuild, NO oil has been burnt. There is obviously a build issue with these engines. Push for engine rebuilds! I went from 1L/1000km to no oil usage at all.
  8. #1548
    Singapore
    Quote Originally Posted by skoobysGTI View Post
    Hi Guys
    Thanks
    Scott
    Please provide the part numbers to us for the items thats been changed will you? Yours CAVE or CTHE engine?
  9. #1549
    Jul 2012
    victoria park, WA
    Quote Originally Posted by Zakarados View Post
    Hi Zakarados
    How did you push for an engine rebuild?
  10. #1550
    May 2013
    Qld
    Re: Polo GTI High Oil Usage - Discussion Thread
    Is there any way of having the cats inspected?
    Just cleaned the car and i swear there was 4-5mm of black stuff around the tailpipes
    Needs oil as well. Need to drive it upto temp and inspect but coldish the stick was bone dry.
    Park it outside VW with signage uses more oil than a rotary or something.
    I know ill be taking toolboxes of the truck and putting the car on the tray and leaving it parked outside the dealership with big banners if they dont play ball.
