Page 110 of 226 FirstFirst ... 1060100108109110111112120160210 ... LastLast
Results 1,091 to 1,100 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1091
    Jan 2009
    Quote Originally Posted by iigx View Post
    My new engine was delayed so now its going in on the 29th of January.
    Anyone else here had their engine replaced yet and have any advice ?
    I want to ask and get proof it is a "new" engine, but is there anything else ?
    Maybe you could make a note of the engine numbers and compare old vs new?
  2. #1092
    Dec 2012
    Melbourne, VIC
    If it is a new engine then it will have a new engine number.
    They could also do an engine rebuild in which case it would be hard to know exactly what they have done, other than trusting what they say.
  3. #1093
    Apr 2012
    Queensland
    Took my 12.5 Polo GTI For its 15,000 km 1st service to Goldcoast VW very happy with service and Their attitude complained about high oil usage they acted on it and ordered the part ....
    As per TPI 202552016.... Crankshaft ventilation Hose ( proper name not oil breather hose )
    Also ordered a new Brake boost sensor as it was faulty . Part number G294
    Carried out campaign 37 G7 DSG Software upgrade
    OIL used was Valvoline Synpower XLIII 5W 30
  4. #1094
    Jan 2013
    Queensland Australia
    Quote Originally Posted by Lock & Load View Post
    I got a call from them today also about getting this part. They said I wasn't the 1st to do so today. You beat me to it.
  5. #1095
    Apr 2012
    Queensland
    I stand to be corrected on this ....... but the Crankshaft ventilation hose works by allowing crankcase to breathe easier stops it from pressurising , means oil is not forced up beyond the piston rings in to the combustion chamber thus reducing pressure in the sump .
  6. #1096
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Melon Head View Post
    It doesn't because all they replace is the block and pistons, the head stays the same which carries the engine number. An ingenious thought on Vws part so they can continue replacing blocks without anyone the wiser.
  7. #1097
    Dec 2012
    Melbourne, VIC
    very cunning sly dogs
    hahaha
  8. #1098
    Singapore
    Quote Originally Posted by gavs View Post
    A revelation to me. In this case could we replace a new 1.6L block in and stay legal?
  9. #1099
    Dec 2012
    Melbourne, VIC
    Without knowing these engines well, my assumption is, it is unlikely you could do that.
    If the 1.6 L block has different bore centres or bore diameters then you have an issue.
    Is the combustion chamber in the head or is it in the top of the pistons?
    The other question is will the cylinder head even bolt onto the 1.6L block?
    You could however certainly change the crankshaft and conrods to increase the stroke of the 1.4L
    EDIT: It is so much cheaper to get an APR Tune though, and if you still want more power then put in a better intercooler
  10. #1100
    Jul 2012
    6,000km of mostly city running around, mostly in Sports mode, and just topped up with 1L of Liqui moly
    Mk8 Golf GTI
