Page 102 of 226 FirstFirst ... 25292100101102103104112152202 ... LastLast
Results 1,011 to 1,020 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1011
    Sep 2012
    NSW
    Quote Originally Posted by MJKooLio View Post
    Guys, go get the Breather hose was replaced! I got mine done last week and it doesn't chew up as much oil as it use to!
    This will be on the cards early next year...
    How does does this process take?
  2. #1012
    Oct 2012
    Just order VW part #03C 103 474 AD, cost $165, it's plug & play. Your time is worth much more than this after you've gone through the mill argueing & debating how much oil you should/shouldn't use.
    I was told 1L/1000km is acceptable oil usage by Austral VW in Brisbane. That means 15l consumption annually. 5l of 5W30 costs $75 min. So based on this consumption rate (which is totally unacceptable, but OK by VW) you are in front in less than a year. That way (replacement) VW has no excuse for consumption if it remains as they have no other solution.......
    I reckon it's an inadequate oil sparation issue. The one in the timing cover meant to do it is too small. There is an engineering issue, routing in an external separator is my next solution.
  3. #1013
    Italy, Piemonte
    Tolerance for VW is 1 liter every 2.000 Kms, as stated in the user manual.
    If you have an higher consumption you must have the breather pipe for free and in the meantime oil top up for free...
    If the consumption won't be better also after the pipe change, you can ask for a new engine and in the meantime top ups are again for free...
  4. #1014
    May 2011
    Quote Originally Posted by fontana302 View Post
    Seriously, it all comes down to the dealer you take it to. Without question, my dealer booked it in to be fitted and the process took 1/2 a day.
    My consumption wasn't super excessive (as some on here) but I think that now some dealers know all the issues and rather than fighting customers, they're just replacing stuff. I can't stress how finding a 'good' dealer helps the process........
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
  5. #1015
    Aug 2012
    wgong
    do MY13's come standard with this part? or is there anyway to tell?
  6. #1016
    Oct 2012
    It's a 10 minute job to fit the new oil breather tube, not a half day:
    1. Pull up engine cover at front & slide forward to remove.
    2. Remove 4 Torx screws.
    3. Pull off tube.
    Replace is simply reverse order.
  7. #1017
    Mar 2012
    Cronulla, NSW
    Quote Originally Posted by prcurrie View Post
    Will any dealer do this for free? Even if I didn't buy the car from them?
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
  8. #1018
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by Lemonskin View Post
    Any dealer should look after warranty work. But don't expect them to trust anyone else's oil consumption test. I gather they don't make much money from warranty work, and so may try to stall you (by making you redo an oil consumption test, for example).
    A savvy dealer will give you very little trouble, as an investment, in the hopes you will choose their service department again in the future.
  9. #1019
    Dec 2012
    Athens
    3. Pull off tube.
    It is not as easy since the midddle return (the one that ends up just before the throttle body) needs to be slightly heated and shaped into correct form so it does not break with vibrations.
    It also needs the clip attached to its end (at least in my cupra that was the deal).
    Let me ask something those that have fitted the pipe themselves. There was a small rubber plug at the end of the middle pipe (the one that ens up just before the throttle body). Did you have to remove this in order to attach the clip that secures the middle return to the manifold pipe?
    (perhaps i need a picture)
    Thanks guys.
    BTW i was consuming 950 ml of CAstrol edge every 10K km (which i gues is not bad for the particular engine) . Lets see if that improves with the new breather pipe.
    I own a 2010 Cupra currently in its 2nd engine (MY12.5 spec engine) after having missfires in no3 cylinder of my first engine . Both engine had similar oil consumption though, which is not too bad for a VW.
  10. #1020
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by Varnak View Post
    Wow! Less than a litre per 10k? You are so lucky...
