Page 96 of 226 FirstFirst ... 46869495969798106146196 ... LastLast
Results 951 to 960 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #951
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by BLN355 View Post
    I still don't understand how this breather hose is supposed to help?
    Its clearly a piston ring sealing issue as per the LS1 engines. Oil gets past the rings gets burnt up and blown out the exhaust hence the oil spots on offending vehicles rear ends.
    The problem is in the other direction - during the combustion stroke, pressure from the cylinder gets past the rings into the crankcase which causes excessive flow through the breather, carrying oil along with it into the inlet tract to get burnt up and blown out the exhaust hence the oil spots on offending vehicles rear ends.
    Quote Originally Posted by nomadx38 View Post
    As for the VW spec (VW 507), i think it mostly refers to an "emissions standard" like how many pollutants the oil gives off when burnt, how much drag it has on the crankshaft and thus fuel economy things like that.
    See Why you need to use 504/507 oils in FSI/TSI/TDI engines!
    It's mostly to do with preventing intake buildup fuel not cleaning the inlet tract due to the direct injection
    Resident grumpy old fart
  2. #952
    After thinking mine was a drinker being on the top up mark on the dipstick at 1700ks, just checked it then after a drive and now its at 3600k's and it hasn't moved at all. I have a Shell Helix sticker on my windscreen so assume thats what it was filled with originally. I topped it up with the proper Castrol at the 1700k mark with 1 litre and all seems fine.
    I did the warm it up to temp then give it some stick method to break it in and its running like a dream.
  3. #953
    Singapore
    Done 12,000km now and total combined only have an oil lost of 2mm. Mine is 80% City driving 20% highway. 4 cross country trips.
    I mean, we have heard countless oil issues but does it account for more than 10% of the cars ever produced by VAG group? There must be many owners without oil issues correct?
    Only issue for mine is 4th gear while slowing down from 5000rpm, will encounter a loud "clank" crashing noise around 4000rpm. wonder if its a "end float" adjustment issue for its clutch issue?? Anyone?
  4. #954
    Sep 2012
    NSW
    2,700km in, and topped up 2.5L
    This is horrible! I still have half of a 1L top up bottle I was given, once that is gone, its time to complain and get an oil consumption test done.
    I am losing around 1L/1000km, anyone else getting these high numbers?
  5. #955
    Erskineville, NSW
    Quote Originally Posted by Zakarados View Post
    You won't get a consumption test until after you have done 5000km. VW will tell you that 1L/1000km when running in is normal.
  6. #956
    Sep 2012
    NSW
    Wow, if that is the case, I should just ask for a 5L bottle to last me until 5000km.
  7. #957
    Erskineville, NSW
    yep
    1234567890
  8. #958
    Jun 2008
    Ringwood, Victoria
    Read through the thread mate, there are some with worse consumption than you.
    This is more likely a mechatronics issue, the clutches are self adjusting and unless they were belted with a hammer during assembly (unlikely) then the mechatronics probably is preselecting gear 3 which is a notoriously rattly gear. have a check on the net about DSG rattles, most of them stem from a dodgy 3rd gear selector valve.
  9. #959
    Jun 2008
    Ringwood, Victoria
    Back on topic, I see where nomad is going because I too thought of tracking down the specific Castrol oil due to it being developed in conjunction with VAG etc. etc.
    BUT.
    The 2 times (factory and 15,000km service) that my car had the Castrol oil in it, it chewed through the oil around 1L/5000kms, maybe a little worse. However I have used Liqui Moly Top Tech 4200 on 2 fills now and have seen an oil consumption rate of around 1L/10,000kms.
    I too agree that the car is noisier with the Castrol oil, not that I can remember what it sounds like anymore
  10. #960
    Singapore
    Quote Originally Posted by gavs View Post
    Thanks Gavin, have not updated the DSG software to the latest version. The 1st gear simply shift up too soon and strains 2nd gear too much!
